Keeping the dust off or covering build plans Options
#1 Posted : 15 May 2021 18:40:50
Hi all, BigGrin
Sometimes when mid build you need to keep the dust off your build and you don`t have the finished build cover/case.Blink
Or when building on a paper plan you need a barrier between the plan and the glued parts.
Well this is what I have used. A very light weight, moisture resistant dust sheet that if used as a build plan cover you can use double thickness and still see the plan beneath.
This is a UK product, but appears to be available in other countries looking at the packaging.
The sheet is 3x4 metres, (12 Sq metres), including the outer wrap weighs only 38gms and cost me only £3.
Here`s a link:
https://www.diy.com/depa...3m/5059340015248_BQ.prd
I will be using this to cover the plans of the large scale "Hawker Hunter" I will be starting very soon.Wink Wink
Silent_Running
#2 Posted : 15 May 2021 19:10:48
A great find Derek, I'm glad you've posted this, as the subject of dust on your builds is something I've been thinking about for my builds just recently. Great stuff! BigGrin
This page was generated in 0.141 seconds.
