Airbrushing help Options
Cally
#1 Posted : 07 May 2021 17:20:39
What's the best thinner for acrylic paints? and can water be used?
#2 Posted : 07 May 2021 18:27:48
Hi Cally
The Vallejo range is pretty good but I found a series of 'homemade' recipes on youtube which basically do the same thing for a lot less!
I tried such a thinner with the Vallejo Metal Colour paints and it definitely worked better than plain water which I used the first time.
The recipe is:
2/3rds water (distilled if you live in a hard water region)
1/3rd Isopropyl Alcohol (Rubbing Alcohol)
About 10 drops of Glycerin
Plain water will work but the added isopropyl and glycerin improve the mix.
Have a look on youtube and you'll find dozens of videos (the airbrush cleaner works great too!)
Robin
#3 Posted : 07 May 2021 20:25:10
I generally use the thinner the manufacturer recommends and defintely use a flow improver. Acrylics are fantastic.The only issue I have is they can clog the tip of the airbrush and then they "spit" a big glob of drying paint right onto the surface you are painting so frequently check your tip and thin the paint a bit to get smooth flow.
Cally
#4 Posted : 07 May 2021 21:38:37
Many thanks Fellas. Had the spitting issue with my first go last week using only water. Glad i asked now!!
This page was generated in 0.143 seconds.
