New build tweak Options
Blobthebuilder
#1 Posted : 18 April 2021 10:49:25
Rank: Amateur Level 1
I've put together the whole hull structure had it on a perfectly flat surface clamped down and 30+kg weights on top over night, it's all glued well but when I flipped it over this morning there is a slight ridge between 2 rear base plates my question is would it be safe enough to gently sand them flush with each other or will it affect anything else going down the models line.
I had a hasegawa yamato that is flat bottomed ut it's largely been mothballed now
Silent_Running
#2 Posted : 18 April 2021 12:22:32
Hi Mark,
Could you please post a picture and then we can give you more accurate advice.
Kind regards
Glenn BigGrin
Blobthebuilder
#3 Posted : 18 April 2021 12:49:43
Hi Mark,
Kind regards
Glenn BigGrin
I can't upload pics sorry but I gave a gentle sand and its all good and level, didn't need much
