Another very nice update Budgie, she's certainly taking shape now..... excellent work.... Regards Alan
 Rank: Pro     Groups: Registered
Joined: 25/04/2014 Posts: 374 Points: 1,134 Location: Mandurah W.Australia
Hi Budgie Your build is looking really good and I'm getting quite a few tips from it - thanks, mate.... I see your model has a cruiser type stern - same as mine - so I will be watching to see how you clad it... I'm currently working on the rudder and rudder support frame and will be posting in a few days... Regards JohnP
John Passmore wrote:Hi Budgie I see your model has a cruiser type stern - same as mine - so I will be watching to see how you clad it... Regards JohnP Hi John had a wee play about with the stern I see what you mean The angle of the bow will not allow the planks to lie flush unless I use very thin strips Think I will be laying the 2nd planking as near to the bow as possible without trying to bend the planks around it As she will be getting painted I will use a filler or putty or sawdust mixed with glue to fill the gap between each side of the planks around the bow and sand to shape Looking forward to your next update budgie attached the following image(s):
Hi taking shape very nicely with you well for the rest of the build cheers mick. Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
 Evening Folks Thanks for posting Mick appreciated I re enlarged the fwd deck template and was a bit disappointed that there is a good sized gap Hey HO Decided to start the laying of planks ...I will call this the 1st layer of planking as it is being layed on the outer frames (previous ones were flush with frames) I will double plank where the armour belt is to be replicated Just using elastic bands and drawing pins to hold in place at the moment No doubt where the planks are more springy they will need to have pins pushed through the actual planks to hold them in place Plan is once 1st planking completed sanding and filler used to produce a smooth hull Thanks for lookin' budgie attached the following image(s):
I hope your loved one doesn't follow your channel or you might be in deep water LOL. Regardless, your hull is coming along just fine now. Waiting patiently for the start of the superstructure and fittings. Happy building David
budgie wrote: Evening Folks Thanks for posting Mick appreciated I re enlarged the fwd deck template and was a bit disappointed that there is a good sized gap Hey HO Decided to start the laying of planks ...I will call this the 1st layer of planking as it is being layed on the outer frames (previous ones were flush with frames) I will double plank where the armour belt is to be replicated Just using elastic bands and drawing pins to hold in place at the moment No doubt where the planks are more springy they will need to have pins pushed through the actual planks to hold them in place Plan is once 1st planking completed sanding and filler used to produce a smooth hull Thanks for lookin' Hi Budgie You're doing a really nice job on the hull...  I not the curve on your stern is much tighter tan the one on mine which is a bit broader and longer...but you are overcoming the problem very well... I will use Pollyfiller too but I had to go and buy mine as the missus didn't have it in her kit... Best regards JohnP
 Evening folks Only got a wee bit of the planking done this week  SWMBO "cracked" a smile so had to hand back her foundation budgie attached the following image(s):
budgie wrote: Evening folks Only got a wee bit of the planking done this week  SWMBO "cracked" a smile so had to hand back her foundation Hi Budgie She's coming along really well now. Shall be watching to see how you do the "hard bits" around the bow and stern... I've a little more progress with my build too... Regards JohnP
 Hi Folks  Still making slow progress Glue takes a long time to dry in this cold weather  Glue dries clear but still white when I go out to the shed the following evening Mind u I have been using a generous amount of glue for each plank Started removing the stern filled in area, to refill once planking done Anyhoos pics moving towards bow and stern budgie attached the following image(s):
 Hi Folks been furloughed for a few weeks so decided to replace my shed The old one leaked quite badly....yeah built it myself  tried repairing but came back to haunt me I unscrewed all the tongue and groove planks and used them to "double plank" the inside of the new shed I would have preferred to have painted inside a lighter colour but covering a very dark wood stain would require a few tins of paint No way should the roof leak now as i used rubber instead of felt Anyhoos thought I would post pics of my new den as it will never be this tidy again  The table tops and drawers were saved from going in the works skip Looks like if I want to do any sanding I will need to wait till SWMBO goes to the shops so I can do it in the kitchen budgie attached the following image(s):
That is a beautiful job on the shed Budgie! Looks great and is about four times the size of my attic workroom! There is so much good stuff wasted and sent to land fill even in these days of recycling! When I built my original workroom on to the back of Dad's garage many years ago, Dad was the Head of Security in the then Plymouth Polytechnic (now a University) Student Union building. The roof panels were made from perfectly good Polytechnic blackboards - they had decided to replace all the traditional blackboards with green ones! Then they complain about government funding shortages! That is a 'model space' to be proud of! Robin. First wooden ship: The Grimsby 12 Gun 'Frigate' by Constructo Second: Bounty DelPrado Part Works Third: HMS Victory DelPrado Part Works 1/100 scale Diorama of the Battle of the Brandywine from the American Revolutionary War Diorama of the Battle of New Falkland (unfinished sci-fi), Great War Centenary Diorama of the Messines Ridge Assault Index for the Victory diary is on page 1
 Morning' Folks Moving all my bits back into the shed and checking how far I have gotten on the Gneisensau Placing a hull template shows I am way out I don't understand  as I have not adjusted any off the slots on the false decks or frames to make them fit Ah well I will start again (at least this time I will be building the same model) Take care Folks and thanks for lookin' budgie attached the following image(s):
 Dejavu Not wanting to cover the den in sawdust just yet so using card just to see if I end up with same problem with gap on fwd deck and gundeck opening not quite rained up budgie attached the following image(s):
Its such a shame to see you having to start again and sincerely hope you can identify the reasons for ending up with a gap on the stern deck section. Will be following as usual.... Regards Alan
Hi Budgie, Not quite sure if there is a connection here, because I have no knowledge of this model at all.... The discrepancy in the template looks to be about the same as the gap in the deck to me. Could something have "slipped" during construction? Or am I being naive? Cheers Chris
 Thanks for comments Guy's As I did not have to alter the position of any slots for the horizontal decks to slot into the frames i cannot fathom out why there is such a big misalignment. Maybe I am being too pernickety I have gone and confused myself even further by: As the Gniesenau is the sister ship of the Scharnhorst and they were both 144.6M long i have found that the 1/100 scale plan I purchased for Scharnhorst is a couple of centimetres longer than what I have built so far on the Gniesenau Which is more accurate? the plan or the card model? need to get my measuring stick out The plan is 150cm long so the Scharnhorst has grown 5.4M But the card model is pretty much bang on  length wise Maybe the UPPER frame templates were not as square as I thought or perhaps the thickness of the mdf has made the difference Ah well I like seeing the skeleton come together budgie attached the following image(s):
Hi Budgie I'm in Tasmania for a few weeks and have just caught up with things... I had the same problem of a a gap of about 5mm between the two deck plate joints. I fixed that by placing a plate across the seam, which joins the two deck plates nicely...  This leaves a little channel the thickness of the ply which I will fill with wood putty then sand down smooth...  This join will be covered eventually by the forward part of the superstructure... Regards JohnP
