Brake cooling Hoses Options
mr_frog
#1 Posted : 11 April 2021 19:39:51
Rank: Amateur Level 1
Less than Impressed by the kit's effort at re-creating these parts.
Even if you get them to fit, the steering is then immovable because the parts are so rigid Oh!... and theres a bloody great seam down the middle.
My solution... a large 'flexible' straw. It can be bent to shape and the straws I got were a perfect push-on fit.
mr_frog attached the following image(s):
JOHN-GT40
#2 Posted : 11 April 2021 21:37:19
Looks real good
JOHN-GT40
#3 Posted : 11 April 2021 21:38:23
I have ordered 9mm internal diameter non split black flexible conduit
Hope this helps others out
Thanks
semaj
#4 Posted : 12 April 2021 21:57:21
Thats a real neat idea, I like that!
Building:
Complete:
mr_frog
#5 Posted : 13 April 2021 18:52:27
I hope the conduit works well.
I'd considered that but wondered if it would be flexible enough.
The diameter you've ordered sounds about 'bang-on'.
JOHN-GT40
#6 Posted : 21 April 2021 21:37:20
Flexible conduit non-split made out of nylon
Internal diameter 9mm
Fits like a glove and as flexible as a rubber band
I ordered a 1 meter length of eBay uk at a cost of £3:00
Hope this helps you all
Thanks
John-gt40
JOHN-GT40
#7 Posted : 16 May 2021 22:25:50
Look at the image on my build page JOHN-GT40
this will show the non split convoluted flexible conduit installed
Thanks
This page was generated in 0.270 seconds.
