Cockpit Canopy won't close all the way Options
1000Droids
#1 Posted : 12 April 2021 18:21:18
Has anyone else had problems getting the canopy to close down onto the fuselage tightly? It seems to be stopped by the front edge of the control panel holding it up. Please help!
#2 Posted : 12 April 2021 19:21:15
There is a slight gap on mine as well, not to much to worry about. I did try and push the front pipe away as I thought that was causing it.
1000Droids
#3 Posted : 12 April 2021 20:26:48
Thanks Mark! If a Pro like you has the same issue, it is not just me.
spacejunk
#4 Posted : 29 May 2021 08:25:57
Have you screwed down the cockpit dash to the cockpit shell. I noticed it doesn't sit on the screw pegs well and needs some fiddling.
Virgil Tracey
#5 Posted : 05 July 2021 17:45:18
The magazine omits 4 screws that pulls down black control panel to the cockpit shell.
You need to put these screws in before the canopy lies flat
This page was generated in 0.085 seconds.
