How to apply wash without stripping away clear coat Options
bfam4t6
#1 Posted : 12 April 2021 00:39:19
What's the proper combination of products, and order of application, needed to use the Tamiya Panel Line Accent Washes without screwing up previous coats?
I've been using these products, applying them in the order shown, several thin coats each.
I wanted to add a bit of wash to the shiny new hardware I added to my seat brackets, and you can clearly see where it stripped away and damaged the semi-gloss clear coat on the surrounding areas.
I've had similar issues in other areas previously, namely the engine and transmission. Fortunately, a smudged engine doesn't bother me. Nonetheless, I would like to figure this out.
Any insights are appreciated!
-Dustin
-Leonardo Da Vinci
Currently Building:
Porsche 2.7 RS
Currently Collecting
Mustang
#2 Posted : 12 April 2021 08:49:10
Personally I don’t use Tamiya, I don’t like them so I can’t really answer your question all I can do is what I use.
With all my models I use a car primer from a spray can grey or white depending on final colour, don’t use any of these special model primers.
The only paints I use are Vallejo model or air then once that’s done it’s a coat or two of klear then again once completely dry I use mig panel lines or washes.
Never had an issue with these damaging the paint or model.
Built:-. HMS Bounty, RMS Titanic, MP4-23, Flying Scotsman, Aston Martin DB5, Honda CB750, Mustang, R2-D2, Jaguar, DeLorean, Testarossa, Stage Coach plus many plastic kits.
Dry dock no room to display:-. Bismarck, U96.
To build:-
. HMS Hood. HMS Victory. Cutty Sark. SoS, Lancaster bomber. DR1 Triplane. JU-87. Plus many many plastic kits.
This page was generated in 0.089 seconds.
