Joined: 11/02/2016 Posts: 36 Points: 88 Location: Edinburgh
Less than Impressed by the kit's effort at re-creating these parts. Even if you get them to fit, the steering is then immovable because the parts are so rigid Oh!... and theres a bloody great seam down the middle. My solution... a large 'flexible' straw. It can be bent to shape and the straws I got were a perfect push-on fit. File Attachment(s): I3.jpg (323kb) downloaded 65 time(s). I1.jpg (356kb) downloaded 59 time(s).mr_frog attached the following image(s):
I have ordered 9mm internal diameter non split black flexible conduit Hope this helps others out Thanks
Joined: 05/03/2017 Posts: 531 Points: 1,710 Location: Midlands, UK
Thats a real neat idea, I like that! Building: Ghostbusters Ecto-1, Ford GT40, Gone in 60 seconds Eleanor mustang, Shelby Cobra Complete: R2D2, Red Bull RB7 RC, Battleship Bismarck, Shelby GT500 'super snake'
I hope the conduit works well. I'd considered that but wondered if it would be flexible enough. The diameter you've ordered sounds about 'bang-on'.
Flexible conduit non-split made out of nylon Internal diameter 9mm Fits like a glove and as flexible as a rubber band I ordered a 1 meter length of eBay uk at a cost of £3:00 Hope this helps you all Thanks John-gt40
Look at the image on my build page JOHN-GT40 this will show the non split convoluted flexible conduit installed Thanks
