The cylindes group is also smoothed. But before starting to think about the exhaust manifolds, I must first put together the engine in its total size. The upper part does not distinguish between the head, fan cowling, fuel system… it looks like the whole cooling cowling but in reality it is not. The Porsche engine is framed on the front… ..that does not exist on the front of the RSR… well, I started by eliminating it here too. But by removing it, all the crack remains due to the absence of the front frame piece. I removed what I needed and started working to close this gap. Another problem: the timing covers. The carters have an external rib which in 1: 1 are used to fix the front part of the frame that is no longer there. The right timing cover has the correct rib or eyelid and at the right height. On the left instead: - no right height (remains too low compared to the upper half colored in silver) - no rib I acted like this: - I raised the timing cover by calculating the missing thickness and placing it at the same level as the upper part. - I took out the wrong rib - I filled the loop for the screw - I recreated the most protruding rib Finally assembled everything to see the overall effect ... .. the screws on the casings will disappear ... but for the moment I need to keep everything squared                   Collection active: Lotus 97T, Audi Quattro A2, Vw Maggiolino '60
Viewing the 2.7 engine pics online, the Dea engine brings to light other inconsistencies and mistakes. The top of the timing cover has ribs found on other flat sixes… but not on this 2.7 With the dremel I smoothed out the ribs and reduced the height of the upper timing cover bolts I continued and I think finished the operation of opening the engine compartment, eliminating the last crossbars. I also cut by eliminating the original engine mounts, as on the RSR the engine is supported by that trapezoidal frame mentioned above. I repositioned the engine: the Eidai frame has a correct wheelbase and if my Porsche had been high from the factory even in depth I think it would have been fine. Having lowered the entire car body by 14 mm if I replicated it on an equal footing, I would have an inadequate ground clearance and the turbo downpipe would be scrap on the ground.          Collection active: Lotus 97T, Audi Quattro A2, Vw Maggiolino '60
My good model friend of Riccardo always tells me: "the man who makes models with legos" Replicating the slightly V-shaped central bracket that follows the physiognomy of the monobloc is possible to scratch but it is a long job. My Danish friends served me the solution (as usual) on a silver plate. I Take 2 bricks, created the loop for the central frame and created the loops for the other lateral ones. This frame will become load-bearing for both the engine and the turbo. To center it at the "v" of the base, the perfect position falls on the side of the side chassis struts. I will open a slot in order to drop from the top and set the frame which will then be fixed to the monobloc by means of 4 studs (as on the real RSR) On the central plate we will then have to think about how to fix the Turbo and the heat shield. A lot of work to do, but i'm think on the right way.            Collection active: Lotus 97T, Audi Quattro A2, Vw Maggiolino '60
Thank to Roy and Kev for advice of pics. I changed the linked and added the last works. Now i think is visible. Sorry for my bad english and i hope you also enjoy with pics. Collection active: Lotus 97T, Audi Quattro A2, Vw Maggiolino '60
I started with the main part of this conversion: the turbo. Making me the turbos by myself was and is a difficult to made and also impossible for me. So for the 0.70 cent I took a keychain with a compressor (or cold side of turbo unit) attached. Given the generous dimensions, the problem was the exhaust side turbo (or hot side) which also on the RSR is slightly smaller in diameter. Having various pieces of the mp4/4 .... I borrowed an IHI compressor (which will then be modified in the connection for the downpipe to the exhausts and will be modified for the exhaust outlet) In the middle I have the hub on which the various lubrication pipes will then be applied. I drilled the hub, I disassembled the compressor and drilled and and then I modified the turbo of the mp4 to insert a 2.5 m nut Starting from the compressor to get up to the turbo, there is a 16mm Allen key that crosses the whole body and screws onto the turbo itself .... practically in reality it would be the shaft, in the model it is the hub that holds everything together the whole turbo compressor unit . Once the turbo is paired and created, it's time to fix it to the crossbar. I created the bracket that supports the turbo with 1mm aluminum. I pierced the "breech" of the turbo, fixed the bracket and finally I bent it in a U shape to go and slip back into the usual turbo screw-shaft. Once shaped, I then fixed it to the crossbar using 2 Allen screws. Given the weight and size, the glue was absolutely not practicable, furthermore making everything removable is easier for modifications, coloring and tests with the exhausts.                     Collection active: Lotus 97T, Audi Quattro A2, Vw Maggiolino '60
Beautiful work, a real pleasure to see..... Regards Alan
Once the group of turbo/frame was joined together, I started the work on the cylinder. I calculated the point to drill and create the exhaust port. I will need the six holes to insert 6 raised allen screw. The head of the Allen screw is of the same diameter as the future pipe for the manifolds, the Allen screws therefore act as a connection for the manifolds. With an old bit and hammer I made the graves to have the correct centering for drilling ... .. starting from 0.8 and up to 2.5. With a plastic rod I created 3mm thicknesses to raise the Allen screw screwed into the internal part of the monobloc. Finally, I placed the first 6 sectors of my exhaust system. I decided to make it as with the 2T expansions or even the handmade exhausts and then to make the various sectors with the plasticard rod. We'll see if I can do it.              Collection active: Lotus 97T, Audi Quattro A2, Vw Maggiolino '60
Excellent scratch building, look good. Mark Regards Markwarren (Mark) Admin
I have finished the second manifold, they are intentionally inclined and tending towards the right to direct them towards the turbo on the exhaust side. I tried to stagger them to follow the misalignment of the cylinders itself Now I study a coupling flange and then I will work on the last piece and on the 2 pipes that will be used for the lateral wastgate (like RSR)       Collection active: Lotus 97T, Audi Quattro A2, Vw Maggiolino '60
This is becoming a really interesting and different build. Looking forward to seeing what you do next.
Very nice work to date. Looking forward to seeing this progress. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Joined: 25/12/2019 Posts: 218 Points: 659 Location: Manhattan, NY
Great start! Really smart idea for making the custom exhaust. Looking forward to seeing more. -Dustin
“Details make perfection, and perfection is not a detail.” -Leonardo Da Vinci
Currently Building: Porsche 2.7 RS
Currently Collecting Jaguar E-Type, Ferrari F40, Ferrari 250 GTO, Lamborghini Miura, Ford GT40, Ecto-1, Japanese Zero, Porsche 917, Lancia Stratos
Some amazing work going into this. Mark Regards Markwarren (Mark) Admin
Congratulations for being recognised for the Build of the Month award.... Very well deserved, excellent work throughout.... https://forum.model-spac...amp;m=339203#post339203
Regards Alan
It's looking amazing. Keep up the posts. They are great to follow.
Some amazing work going into this one. That scratch built exhaust piping is brilliant !! Very well deserved build of the month . Congrats.. Malc.
Guest (5)
