Joined: 23/09/2018 Posts: 154 Points: 471 Location: Cape Town
For some ambient atmosphere inside the cut out I placed on each level a curved acrylic mirror - seems very effective when shining a light on it. Roeland attached the following image(s):
I added most of the flags. Still have work on the cut out and other detail. Roeland attached the following image(s):
Joined: 09/12/2013 Posts: 577 Points: 1,748 Location: smethwick england
She looks mighty fine in full sail Man he took his time in the sun Had a dream to understand A single grain of sand He gave birth to poetry But one day will cease to be Greet the last light of the library...We were here!
I just finished painting the 29 remaining figurines. Some are in position already. Roeland attached the following image(s):
Joined: 25/03/2011 Posts: 1,027 Points: 3,075 Location: Lincolnshire
Congratulations Roland how lovely she looks, what a beautiful build you’ve done on her. And with the sails as well she looks so impressive. You should be very proud of what you’ve accomplished. 👍
Looking fab Roeland, looking fab.... Regards Alan
There's now some more progress on the cut out. Still have to do the 18 blocks and rigging to the middle deck guns and some figurines before I can get everything in place. Roeland attached the following image(s):
A great build Roeland. Well done.  Chris
goddo wrote:A great build Roeland. Well done.  Chris Thank you - much appreciated - although I think your build will be better judging at your progress.
The figurines and all rigging of the guns in the cut out are now in place - the cut out is now 99% finished. Roeland attached the following image(s):
Today I managed to fit the lower studding sail booms on the port side both for the main- and fore mast. I also added extra support to the yards via the burton pendants for the hoisting of the launch. Roeland attached the following image(s):
All looking good. WTG Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Such neat and crisp rigging. Well done Roeland. Chris
After all this time the barrels are now done and some more detail added on the poop deck. Roeland attached the following image(s):
All of a sudden I realise I'm about finished - perhaps a couple of alterations and a display case but in general it is all there. Roeland attached the following image(s):
I din't like the water transfer on the stern so I made some brass letters from 0.2mm brass - CNC engraved and cut out by hand. Roeland attached the following image(s):
Starting to experiment with a brass gun stand for the model. So far I turned the 2 guns. Roeland attached the following image(s):
Roeland, This build is definitely turning into a work of art. Great stuff. Chris
Looks stunning Roeland, credit to your eye for detail.....  .. Really like the look of those turned guns too, they look fab.... Regards Alan
I had to remodel the guns stands as I first had to cut the slot for the milled brass brackets other ways the guns broke off at the weakest point. - slow progress but getting there. Roeland attached the following image(s):
