 Rank: Beginner Level 3  Groups: Registered
Been looking through the builds and i like Wabies stand . Anyone got a link for this stand in the UK or anyother ideas .
Joined: 25/03/2011 Posts: 1,027 Points: 3,075 Location: Lincolnshire
fossie67 wrote:Been looking through the builds and i like Wabies stand . Anyone got a link for this stand in the UK or anyother ideas . Hi fossie, I think the quickest way to get this stand is to send Wabie a PM and ask him where he got it. He will probably even send you the link to it if you ask him. Kind regards Glenn
 Rank: Semi-Pro Level 1  Groups: Registered, Forum Support Team Germany, Official Builds, Tech Support, Moderator, registriert, Administrators Joined: 27/09/2016 Posts: 73 Points: 209 Location: Berlin
Hi Fossie, Here is the Link to the Stand from EBay https://www.ebay.de/itm/...=p2349624.m46890.l49286
You need a M8 Bolt to fix the XWing Greetings Stefan Alle Berichte sowie alle Fotos unterliegen dem Urheberrecht. Verwendung außerhalb dieses Forums bedürfen schriftlicher Genehmigung/Zustimmung meinerseits. © StefanForum Support Teamhttp://www.model-space.com/de/ https://m.youtube.com/watch?v=qIC4f1LE86w
MfG Stefan
Hi Stefan, Very much appreciated thank you Kind regards Glenn
Joined: 16/02/2017 Posts: 26 Points: 77 Location: Cheshire
Hi Stefan, Your build also mentioned you had 3D printed an adaptor for it to fit. Is that something you would consider doing a small production run of? Built - R2D2, Thunderbird 2, X-Wing / WAS Building(Ha!)- Bailed after eight months without pack 15 - Millenium Falcon
Many thanks for pm Wabies
Cracked it . Had a rummage in the shed and i knew i had an M8 thread . In the shed i found a floor lamp . It had a heavy base and 4piece tube upright . Anyway was able to cut down one of the tubes and run the M8 bar through the centre . Bingo nice little table top stand .
