In this update, i built up what will become the stern gallery. Straight forward enough, just adding the supports and the end panel. Next, the instructions ask that you add supports for the lower deck. These seemed a bit flimsy to me, so i used a few of the offcuts from where the hull formers came out of the ply sheet. These, i judged to be the right thickness - thick enough to offer bettere support to the deck, but not so thick that they interfere with the mast when installed. It is essential that these supports are at a right angle to the false keel, otherwise there are going to be problems when installing the deck itself. I used a set square for the first support, then a straight edge for the second. Seemed to work out ok Another deviation was to install the lower deck before planking. No other reason than for personal preference. My thinking being this way you can ensure better fit of the deck. Started laying the first planks. I don't know if i will be using the caulking and trenail effect, as i fancy leaving it clean. Will make final decision once fitted and sanded. The pins are there just to help butt them up against each other until the glue dries. CaptnBirdseye attached the following image(s):
Nice progress. Some nice fore-thought with the reinforcement. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
 Thanks Del. If you’d have seen the supplied supports. I think you would have done the same. They are barely thicker than the decking planks Regards Gray
Looking good Gray, excellent progress on show.....  .. Good thinking on the supports, always better to be safe than sorry. Belts and braces to be sure.... Well done.... Regards Alan
 A small update - that took a long while to do! Finished fitting all the planks, and sanded them down. As this deck isn't seen very well, i thought i'd try a few things out on it. To simulate the caulking, i used a pencel along the joints lengthways. Then i scored the joints across the grain with a craft knife. The trennails were made with a drawing pin. I then gave it a couple of coats of Danish Oil to bring out the grain and emphesize the trenails and caulking.  I’m not altogether convinced with the result as to my eyes it seems a bit.....cluttered? I also like the bare look that can be seen in Jack Aubrey’s diary. Will sleep on it before I decide, as easily stripped back if I decide against. CaptnBirdseye attached the following image(s):
Coming along beautifully Gray, very nice work on the decking. A long job laying planking I agree, even longer when you come to planking the sides of the hull but I find the task very relaxing..... Look forward to seeing more of this build, she's a beautiful ship when done..... Regards Alan
Very nice work Gray. As you say, rather be safe than sorry with the extra deck supports if they look flimsy. Well done. Chris
 Thanks for looking in, guys, and leaving your comments Always appreciated. Thought i'd share my new invention. I needed a method to 'mass produce' an exact length of planking, and came up with this! This jig just keeps on giving CaptnBirdseye attached the following image(s):
Looking very nice Gray. Mark Regards Markwarren (Mark) Admin
 Thanks Mark, although the jury’s still out on the planking I’ve got some Tanganyka I might try and see how that looks Regards Gray
Looking well Gray. My HMS Surprise was done in tanganyka planks then oiled with Antique oil and look a really nice colour. I will use it again on another ship when I get round to building one lol. https://forum.model-spac...s&m=12308#post12308
Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
That's quite an ingenious use of the build jig Gray and very well thought out too..... One for the memory bank I think..... Well done..... Regards Alan
Nice work there Gray. How are you getting on with that jig? I have the same one and while it is very strong and accurate, it is also quite large. I couldn't wait to get mine off the bench in the end. Still, it does what it is supposed to do and that's the main thing. Chris
 Thanks for looking in guys. Comments much appreciated @Chris, that Tanganyka does look well with just the oil on, and would make a nice contrast in colour to the planking. Food for thought @Kev, the jury is still out on the deck colour. I'm not sure if i like it enough to do the main deck with it. As mentioned, the Tanganyka looks well too. The cutting tool is just an amalgamation of two pieces of equipment that i owned. 'The mother of invention', and all that @Alan, i'm sure a man of your skills has many of these little tips and tricks up your sleeve  , but it was late at night and i needed the jig NOW, so married the two pieces of equipment together. Have to say it works surprisingly well. @Goddo (Chris), If you're intending to build many wooden ships, i beleive this Professional Building Slip by Hobbyzone is the one to own. Yes it's bulky, takes up masses of room, but it's also very adaptable. There isn't many ship skeletons it cannot handle, makes for easy fitting of frames, and the model can be held securely and rotated to help when planking the hull. If anyone is inteested in knowing more about these build jigs, JamesH did a review of it here, for Model Ship World (hope i'm not breaking any copyright here  ), : https://modelshipworld.c...uilding-slip-hobbyzone/
Regards Gray
 Rank: Pro     Groups: Registered
Joined: 25/04/2014 Posts: 374 Points: 1,134 Location: Mandurah W.Australia
Hi Gray That's a brilliant looking model and you're doing a great job of the build....  Love the jig - what a monsta!... Regards JohnP
 Thanks for looking in John  Appreciate the comments. The judge is not cheap, but very versatile More updates shortly Regards Gray
 Well, i finally decided what i want to do with the deck. Having some 4mm Tanganyka strips in my stash, and thinking these looked a better scale and colouring, i have re-done the deck. I have also had a go at the '4 plank shift' tecnique. This, to me, looks better and less 'cluttered'. To highlight the caulking, i used a knife to score the edge of the planks, then used a pencil to 'fill in' the edges. The trenails are simulated by use of a fine drill bit, and then a few coats of Danish Oil to finish off. This also acentuates the illusion of the trenails  . Not sure if the photos really do it justice, as in the flesh the effect looks a million times better! Hope you agree? CaptnBirdseye attached the following image(s):
Now that does look a lot more authentic Gray, excellent work.....  .. Little tip for you... I tried using a knife as you did but found I ended up cutting into the strips. I use an awl or scribe.. When the planks are fitted, set a ruler along the edge of the plank and run the awl along the caulking line. Gives a slight indentation rather than a score, then run the pencil along the line... gives a nice neat finish..... Regards Alan
 Thanks Al, another great tip  Timely too, considering the main deck is next Regards Gray
