4 Pages 123>»
Between Decks Options
Mustang
#1 Posted : 30 March 2021 21:44:13
I was going to start another cutaway build but instead I've gone with this, I brought this second hand and I know I'm missing a couple of piece but I can replace them as and went needed.
Its called Combat Place or Between Decks but I like the sound of Battle Stations...
Scale is 1/23
Built:-. HMS Bounty, RMS Titanic, MP4-23, Flying Scotsman, Aston Martin DB5, Honda CB750, Mustang, R2-D2, Jaguar, DeLorean, Testarossa, Stage Coach plus many plastic kits.
Dry dock no room to display:-. Bismarck, U96.
To build:-
. HMS Hood. HMS Victory. Cutty Sark. SoS, Lancaster bomber. DR1 Triplane. JU-87. Plus many many plastic kits.
Mustang
#2 Posted : 30 March 2021 21:47:05
Whats in the box.
To build:-
Mustang
#3 Posted : 30 March 2021 21:48:28
It comes with a big instruction manual about the same as the stage coach, plus a massive double side sheet.
To build:-
Mustang
#4 Posted : 30 March 2021 21:51:31
As I said this was second hand and as so the previous person had tried to build this.
No idea what glue they used but its like hot glue gun stuff.
So some damage here and there.
To build:-
Mustang
#5 Posted : 30 March 2021 21:56:28
First up was to make 3 frames for the main unit.
Each one has to have two holes drilled so you can add some dowel to help support the joints, I just used cocktail sticks why waste a good dowel.
To build:-
Mustang
#6 Posted : 30 March 2021 21:58:40
Next was to add the cross beams 3 at the top and 3 at the bottom.
I've only glued the bottom once here the top ones are just dry fitted to help position.
Left that for a day.
To build:-
Mustang
#7 Posted : 30 March 2021 21:59:45
Following day fitted the upper beams.
To build:-
#8 Posted : 31 March 2021 00:28:52
These builds really are a lot of fun to put together with endless scope for adding your own level of additional detail. Will enjoy seeing this come together, so enjoy and good luck with the build......Cool Cool
#9 Posted : 31 March 2021 11:09:59
Another interesting build. The scope for these is endless. Looking forward to your next update.Love Love
#10 Posted : 31 March 2021 11:27:29
That looks an interesting project Ian and I'm sure it will build into a great display piece (and talking point) at the end of it?
I'll be watching! Cool ThumpUp
Kev
goddo
#11 Posted : 31 March 2021 14:09:26
Off to a good start Ian.
Good luck with rebuilding this kit.
#12 Posted : 31 March 2021 19:41:57
Hi off to a very good start ,they do make great display piece, will be following as you progress cheers mick.BigGrin
Mustang
#13 Posted : 01 April 2021 18:38:46
Well I’ve got to where the other person got to and I can see why he gave up.
The inner uprights that sit between the outer and middle uprights are to small, where the manufacture has cut them they didn’t take into account the added distance to the top of the uprights.
I’ll post photos tomorrow, spent most of the day helping a friend that’s designed and made a stand for building 1/12 scale bikes like the Tamiya ones.
Then I got about an hour look in on this.
To build:-
Mustang
#14 Posted : 01 April 2021 18:39:51
Oh and thank you all for looking in BigGrin
To build:-
#15 Posted : 01 April 2021 19:03:15
Now this looks interestingDrool Drool will be followingBigGrin
Regards PhilCool
Mustang
#16 Posted : 02 April 2021 14:55:46
Hi Phil and welcome.BigGrin
So this is where the other guy got to so from here out its all new so to speak.
The part in question is this long piece which as you can see is the size the manufacture made it to.
And according to the instruction sheet this should sit level underneath the tops cross beam which sits flush of the uprights.
Now I have seen some builds of these where the builder has simple moved the top cross beam down to sit on top of these uprights which is one way of doing it.
To build:-
Mustang
#17 Posted : 02 April 2021 15:02:47
So I've simple pinned some scrap wood to the top and bottom so I can get the uprights to sit flush.
Which give me a slight lip to push the beams up to.
And with the upright beam sitting against the bottom cross beam this is the gap left.
All I've done is glued the bottoms in place and waited then add a small piece of scrap wood to push into the gap with glue, which at the moment is drying.
If you look in the background of the last photo you can see where the manufacture made there mistake as I see it they made these the same hight as the other uprights instead of adding 1.5mm to them.
Either way work, up I prefer to have the cross beam level so when I add the upper beam section it can glue to the whole length instead of just 3 points.
To build:-
Mustang
#18 Posted : 03 April 2021 10:03:34
So from what I can find out about this kits it’s meant to be based on an English 1800 war ship, so I’m thinking of frigates as the design seams to fit what I can see if photos. It can’t be anything bigger as the outside design doesn’t really match the bigger ships.
To build:-
Silent_Running
#19 Posted : 03 April 2021 10:30:47
Hi Mustang,
This kit already seems to have its own challenges, but nothing you can’t sort out with your experience. BigGrin. It shows the value of the forum to beginners though by gaining knowledge from experienced modellers such as yourself.
Great stuff ThumpUp
Glenn
Mustang
#20 Posted : 03 April 2021 19:16:44
Hi Glenn, nice to see you here on my build thank you for the high praise and coming from someone like yourself it means a lot, I just plod along doing what I like and see how it comes out it doesn’t always come out the way I imagined it when I start Blushing Laugh
To build:-
4 Pages 123>»
This page was generated in 0.235 seconds.
