Wings closing problem Options
fossie67
#1 Posted : 29 March 2021 21:12:18
Rank: Beginner Level 3
Got to the place of connecting all wires up and wings .Lights all ok etc but wings open ok ( put shim inplace as per mods ) but will not close .Took it all apart and checked motor .Motor running ok but can someone tell me is it supposed to turn both ways ie one way to open wings the other to close wings Thanks guys .
fossie67
#2 Posted : 29 March 2021 21:59:47
Just to explain a bit more . My motor cog seems to go only one way , have reconnected all wires to check seated ok .
#3 Posted : 29 March 2021 23:10:29
I would check the sockets 13 &14. 14 connects to the switch that detects whether the wings are open and 13 detects when they are closed. The switch may not be connecting.
I assume you have stage 74 complete and have attached the last mains power cable to the board before testing the electronics.
fossie67
#4 Posted : 30 March 2021 06:50:16
Yes i am up to issue 75 . Will recheck connections again but i could not see anything wrong there .
fossie67
#5 Posted : 30 March 2021 10:36:40
Well done some more trials and testing . Just put bottom 2 wings together . opens fine and stops , closes okay now but will not cut out . Took wings off and tested switches . When looking from the side with motor running and you press bottom switch (14) motor stops however with motor running when you press the top switch (13) nothing happens motor keeps spinning . So is it a fault with the board or switch . Any ideas please
Silent_Running
#6 Posted : 30 March 2021 12:21:07
Hi Fossie,
I’m sorry to hear about the problems you are having, I have passed your problem on to the relevant team member to get you assistance. BigGrin
Kind regards
Glenn
#7 Posted : 30 March 2021 20:04:18
The fact everything else works on the board, I would say it is a problem with the switch.
Best option is to request a replacement from c/s.
#8 Posted : 30 March 2021 20:37:21
I agree with Mark.One thing I would check is the socket where the microswitch plugs in to the board just to make sure the pins in that socket are not bent, but it does sound like you may have a faulty microswotcih.
fossie67
#9 Posted : 30 March 2021 20:38:41
Thanks will get on it tomorrow . Looking at the switch i cannot see anything amiss unless te wire is broken somewhere along its length
#10 Posted : 30 March 2021 22:10:18
yes you wont be able to test the microswitch without a multimeter.
fossie67
#11 Posted : 01 April 2021 14:31:04
c/s are going to send me both parts just to be sure . Many thanks guys , when they arrive will let you know how it worked out .
Silent_Running
#12 Posted : 01 April 2021 15:14:57
Hi Fossie,
That’s great to hear, I’m glad it’s been sorted for you. BigGrin
Glenn
This page was generated in 0.287 seconds.
