Looks very authentic. Carl
Hi Carl, Thank you for your response to my build, I have more to add to the water tower such as the pump shed built very much as in 1880 out west. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Very nice work Trev, very interesting build. Mark Regards Markwarren (Mark) Admin
Hi Mark, Thanks for looking more soon tomorrow or Sunday. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Trev, superb piece of scratch building there and have a feeling this dio is going to be full of detail....  .. Look forward to seeing your next update.... Regards Alan
Hi Alan, Thank you for looking in and your comments,your correct about the detail I think you will enjoy the Blacksmith and Barn set up as that is very detailed. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Progressing nicely. Well done Trev. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi Derek, hope you are all ok up there, and thank you for looking in, posting more today of the water tower and pump shed to complete the set. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
UPDATE: Water Tank. This picture shows the part that sits on the front of the water tank, this will move the water tube up and down as as needed also you can see the behind a black wire water gauge,all pulleys turned on my lathe.  The hose will be made from a 6mm drinking straw passed through a small brass holder which had to be soldered and fitted to the tower top platform.  This is the finished water tank. .jpg?width=590&height=370&fit=bounds) .jpg?width=590&height=370&fit=bounds) More Soon Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Now that does look sweet Trev, very well thought out and the finished look is simply fab  ..... Regards Alan
Thank you, Alan. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Love the water tank.  Great work Trev. Mark Regards Markwarren (Mark) Admin
Update: Tower & Pump House. In this part of my build, I really had to stop my self from overdoing it as you can see there are lots of extra bits, like the gearbox on the top platform which turns the sale, or the red valve on the side of the tower. The wind sale I made from a plastic tub the valve turned on the lathe. The first picture shows a drawing of the pump house, the door will be the only entrance to the pump house which has to be built around the tower as in 1800, the building and Tower will be made from Coffee Stirrers. .jpg?width=590&height=370&fit=bounds) To maintain the strength of the Tower I glued 4 sticks together to form a column and then build from that, from this photo you can see the Tower in its early stage. .jpg?width=590&height=370&fit=bounds) Moving on, this picture shows the Tower all most complete, you can see the second stage Ladder reaching up to the top platform and a safety rail made from a 1.5mm brass rod bent and soldered around the black rod which will hold up the wind sale gearbox. The bottom tank will be a feed off for the hand pumps and buckets.  On this close up shot you can see the wind sale which revolves around the gearbox the box is made from a beer tin as you will see I have used a beer can in the Blacksmith build.  These shots are the base of the tower and pump house, also can you see the two small hand pumps and buckets side by side, again turned by the lathe, spouts made by hand (brass rod) .jpg?width=590&height=370&fit=bounds) .jpg?width=590&height=370&fit=bounds) This is the build completed. (notice the cart a bit more added)  More soon Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Mark, Thanks for looking at the build, I must say that I do get carried away some times with builds that why there is a long break between posts such as the tower and the cart it all works !! Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Kev, Sorry, missed your post, and I thank you for your kind comments, I will be posting very soon, and yet another part of the town with plenty of detail. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
 WOW Trev, you can almost hear the tumbleweed rolling around down the street Regards Gray
Hi Gray, Thank you for posting and your kind comments, more very soon. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Sorry, missed your last post Trev, and just catching up. Love what you are doing.  Modelling at its best. Mark Regards Markwarren (Mark) Admin
This is really progressing very well Trev and you can never overdo on the detail.... The thought and care going into this is just superb..... Regards Alan
