4 Pages <1234>
Racing E Type - CUT 8 Options
#41 Posted : 23 March 2021 17:16:32
Thanks Mark. Comments are always appreciated.
I've moved ahead a bit now and completed most of the interior.
Rear brake vent pipes in, rear part of the roll bar in place, Fire extinguisher system scratched, seat trimmed and fitted and the rear body is now fitted to the lower pan. Under the car is now matt black.
Hopefully you can now see the logic of painting the upper part of the body beforehand.
The lower joins have been filled and sanded back so next up will be a lot of fiddly masking so the light blue can be attended to.
I've also removed the front bonnet trim strips and filled the lamp bezel locating holes as the bezels won't be used.
On we go...
#42 Posted : 24 March 2021 10:06:19
That is coming on very nicely Roy.Love Love
#43 Posted : 24 March 2021 11:02:08
That's looking very good Roy. As you say there'll be some awkward masking to get the sides painted up.
#44 Posted : 24 March 2021 20:03:45
Very nicely done Roy, it takes a lot of skill to do the sort of cut and chop modelling that you are clearly so good at. It's not easy to achieve such a well engineered and precise result from combining kits and scratchbuilding parts as you normally do.
Very well done Roy, looking great so far. Cool ThumpUp
Kev.
#45 Posted : 24 March 2021 20:23:26
Many thanks for the comments you guys.
Over the past 2 days I've masked, primed, rubbed down and top-coated the light blue.
Yes, the masking was VERY time consuming but here we are now.
The door skins aren't fixed. They are just fitted loosely for painting purposes.
#46 Posted : 25 March 2021 20:41:09
Very nicely done. Love Love
#47 Posted : 25 March 2021 20:58:47
Thanks for peeping in Mark.
OK - next is the the bonnet (hood).
After making a shape template in paper, the front pattern was masked in using Tamiya thin-line masking and then ordinary masking tape.
Once sprayed in primer and then flatted down, it was given 3-4 coats of blue.
I'm pretty happy with the result so far.
andali15
#48 Posted : 25 March 2021 21:55:20
Great work as usual Roy. Love the colour. Enjoying seeing it come together. Andy.
#49 Posted : 26 March 2021 17:17:46
You should be very pleased with the results from your careful masking and spraying Roy, that looks fabulous. I love the colour combination of the graphite upper panels and the pale blue lowers, very nice!
Looking great, keep up the good work! Drool ThumpUp
Kev.Smile
#50 Posted : 27 March 2021 00:20:09
Stunning work once again Roy, looks fab.....Love Love
kpnuts
#51 Posted : 27 March 2021 09:15:20
Incredible work roy and great progress
#52 Posted : 30 March 2021 09:14:50
Very nicely masked and painted Roy. Looking great.
#53 Posted : 01 April 2021 15:23:21
Once again, my thanks to all those who peep in on my waffle, and for the kind comments.
One of the biggest headaches with this kit is fitting the doors and the inner door panels.
They literally never fit or line up. I've built about 10 of these over the years in different guises and they were all the same in this regard.
This time I decided to attend to the outer body door skin first and get it to line up.
That part isn't big problem though.
The way Revell have engineered this kit means that the door inner panel and window have to be glued in place on the open door skin once it's fixed to the body.
Almost impossible.
Fortunately, this car being a racer, it has a plain flat inner panel covered with dark blue rexine and a simple handle to open/close the door.
I decided to cut the door panel apart and glue it to the skin which wasn't yet glued to the hinge. That way, I could remove the door, adjust the inner panel and re-fit it.
Once it all lined up nicely, the door was then glued to the hinge.
The cut-off section could then be glued back and eventually I'll cover the inside with blue matt vinyl.
Radiator in place, assorted pipes etc added in the engine bay.
Moving along...
#54 Posted : 01 April 2021 22:50:32
Very nice work Roy, that colour scheme looks fantastic.Love Love
#55 Posted : 09 April 2021 16:32:52
A fair bit more done on this one now.
Rear screen surround has been masked, blacked and rivet detail added.
Both doors are on, lots more added at the front end and the bonnet/hood has the air intake pipe and brake air deflectors added.
Inner door panels covered in satin blue vinyl to replicate the rexine on the real car. Handle still to add.
Home stretch on this now so the Datsun and resin Porsche will be pulled next - along with the other McLaren.
#56 Posted : 09 April 2021 20:09:12
That's looking very nice Roy and boy do you get through these builds very quickly! I wish I had more free time to speed things up on my own builds! Crying
Kev.
#57 Posted : 09 April 2021 20:27:07
Many thanks Kev.
Bear in mind I'm now retired so I often spend anywhere between 2 - 10 hours a day building my models.
I do have many other interests - hence the '2' hours bit...LOL LOL LOL
#58 Posted : 09 April 2021 21:33:16
Done to your usual exceptional standards Roy, looking fabulous..... Love the colour scheme....Love Love
andali15
#59 Posted : 09 April 2021 22:28:57
Great following this build. Excellent work as always. Andy.
bfam4t6
#60 Posted : 09 April 2021 23:08:27
Nice work as usual Roy. I really like the window details. Adds a lot of realism.
-Dustin
-Leonardo Da Vinci
Currently Building:
Porsche 2.7 RS
Currently Collecting
4 Pages <1234>
This page was generated in 0.249 seconds.
