Joined: 16/04/2011 Posts: 328 Points: 998 Location: Anglesey
Hi everyone, bit late to the party. Had another partwork on the go, so had to wait. I am completely repainting this to resemble the studio scale model. Not much info on Red 5 out there, so it will be as close as I can to it. I am sticking with the stock electrics/lights. Even thou I'm only upto issue 11 you do get an idea of the size and its big. There is a lot of colours on studio model, Red, blue, grey (various shades) yellow, green and tan. Started of with everything painted in grey primer then I have used Tamiya Lacquer LP-34 (or AS16 spray can) as the base colour A few pics below to show where I'm upto. Will do more weathering as I go. Hope you enjoy. Spudtrooper37 attached the following image(s): Darren
Have an AWSOME day and may the Force be with you always 😉 Building: Millennium Falcon https://forum.model-spac...sts&t=14381&p=7 - Building: BTTF Delorean - Building: Dom's Dodge Charger - Building : X-Wing https://forum.model-spac...aspx?g=posts&t=34899
Very nice work Darren. Mark Regards Markwarren (Mark) Admin
Markwarren wrote:Very nice work Darren. Mark Thank you 🙂 Darren
I found this to indicate where the colours go, I am compiling a list of Tamiya paints I am using. This will be updated as I go. Spudtrooper37 attached the following image(s): Darren
Colours used so far No1 Flat Red X7 No2 Medium Grey XF20 No3 Sky Grey XF19 & Sky Blue X14 (Ratio 3:1) No4 light Blue XF23 Spudtrooper37 attached the following image(s): Darren
I had noticed on a few builds I'd seen that there was a lot of light bleed on the canons. 1. At the base. 2. Where the two aluminium tubes join. 3. The end part. I had resolved 1 & 2 with black paint to the inside parts. Regards the end I was thinking of putting tape around the optic fibre but then I came across a great solution on YouTube, this person had used a toslink cable. I don't have the end part of the Canon yet but the pictures below will give an idea of how it works and it is a lot better than the stock part. You just need to buy a cheap one because these are thin cables, I bought a 5m for £6 of amazon. Just cut of the ends and use the length that is required. Spudtrooper37 attached the following image(s): Darren
A few blaster marks added, hopefully my next issues should arrive towards the end of the month Spudtrooper37 attached the following image(s): Darren
My next issue's arrived 12-16. Primed and ready Spudtrooper37 attached the following image(s): Darren
Doing a great job Darren. Looking very nice. Mark Regards Markwarren (Mark) Admin
It looks fantastic.Re color references google "jason Eaton".He just finished a red 5 x-wing and this guy has had access to the ILM vault where the original models are kept so his red 5 is probably as close to the filming version as you get.I beleive he custom mixes his colors so cant give you specific color recommendations, but his work is just incredible.
I used those optical cables on my Deagostine x wing.
Markwarren wrote:Doing a great job Darren. Looking very nice. Mark Thank you, just working my through it. Darren
darbyvet wrote:It looks fantastic.Re color references google "jason Eaton".He just finished a red 5 x-wing Thanks Carl, the only reference on Jason Eaton I could find was on Red 4 and 1 Do you have a link? The more reference material I can get is better. Darren
I now have my sublight engines working and a bit more weathering, I think I am at a point where I am happy for now. So I won't be posting anything really for a while, my next delivery date is roughly 20th April and the will consist of finishing the underside of this wing and the start of the next wing. So until then keep safe everyone Spudtrooper37 attached the following image(s): Darren
Hi Darren Your weathering looks spot on. Coming on very nicely. Mark Regards Markwarren (Mark) Admin
Markwarren wrote:Hi Darren Your weathering looks spot on. Coming on very nicely. Mark Thank you, when are your build diaries starting again? Darren
Second wing started Also sorted the seam lines on the laser canons. And a side by side comparison Spudtrooper37 attached the following image(s): Darren
Looking good Darren.  I should be getting parts very soon to complete the official build diary. Once that is done I will the carry on with the custom build. Mark Regards Markwarren (Mark) Admin
I signed up to the premium, so the crates arrived. The colour is OK, so I did a repaint on one. What do you think? Also they are great a proper storage crates. Spudtrooper37 attached the following image(s): Darren
Great improvement, looks excellent. Mark Regards Markwarren (Mark) Admin
It's been a while, upto issue 55 but I am missing 46-50 due to out of stock. Just Chipping away as parts come Can't wait when I get to stage of joining the wings to the body Spudtrooper37 attached the following image(s): Darren
