Revell or Tamiya Options
Silent_Running
#1 Posted : 12 March 2021 14:25:06
I’m about to order some acrylic paint I was wondering if there is any material difference if any between the two brands? 😎
#2 Posted : 12 March 2021 15:51:10
Tamiya tend to be lacquer based and revell are water based. I never had good results myself with Tamiya or Mr color lacquer based.
Using either is personal preference.
I use AK paint on most of my builds which a water based.
Silent_Running
#3 Posted : 12 March 2021 16:12:51
Thanks Chris for your reply, that has cleared a few things up. I’ve never used Tamiya paints before you see. I can imagine lacquer is quite difficult to use by the sounds of it! Many thanks 😃👍
Mustang
#4 Posted : 13 March 2021 11:24:12
My personal preference is Vallejo paints both model and air, very easy to use and the only paints I use now.
I used to use Tamiya but hated the smell and the time it took to dry, Vallejo paints dry quick as there water based.
Built:-. HMS Bounty, RMS Titanic, MP4-23, Flying Scotsman, Aston Martin DB5, Honda CB750, Mustang, R2-D2, Jaguar, DeLorean, Testarossa, Stage Coach plus many plastic kits.
Dry dock no room to display:-. Bismarck, U96.
To build:-
. HMS Hood. HMS Victory. Cutty Sark. SoS, Lancaster bomber. DR1 Triplane. JU-87. Plus many many plastic kits.
Silent_Running
#5 Posted : 13 March 2021 21:37:07
Thanks Chris for imparting your knowledge, I will definitely check out Vallejo.
Kind regards
Glenn
