Joe Bergman Pack 12 Personal Warning - Will Show Sectional Build When I do Pack 12 Options
bojazz
#1 Posted : 08 March 2021 02:59:09
Rank: Beginner Level 3
PLEASE FOLLOW SOME ADVICE HERE.
At Step 47-1 I WOULD REMOVE THE CALIPER AND BRAKE ROTOR ASSEMBELY FROM THE HUB. Put the screw and wheel nut in a storage cut with the hub and tire.
Personally, I feel if you install the tire when the when the from wheel assembly is attached.YOU WILL CAUSE DAMAGES TO THE SUSPENSION installed in issue 11.
Follow the process of Step 48 of installing the tire on the hub.
This is now up to you.......
1) You can install the tire on the caliper with the screw and add the wheel nut, or you can wait to get both front end tires on together and keep the front end balanced.
OR
2) After you have installed the body.
The choice is yours.
THINK AND MENTALLY ENGINEER THIS PART OF THE BUILD.
Until Next Time
admin
#2 Posted : 08 March 2021 04:24:21
Thanks Joe, for mentioning this.
It’s utterly dumbfounding they propose to have builders do it this way.
Stay well,
This page was generated in 0.082 seconds.
