4 Pages <1234>
Racing E Type - CUT 8 Options
#21 Posted : 21 February 2021 00:55:59
Excellent work as usual Roy, looking fab as usual.....Drool Drool .. Interesting to see how you're going about modifying the build to a RHD version. Finding it really inspirational for a newbie to plastic modelling like me....Blushing Blushing Look forward to seeing the next steps.....Cool Cool Cool
#22 Posted : 26 February 2021 17:14:55
Many thanks you chaps.
A bit more.
The dash is now sorted with correct gauges, switch labels and bezels made from solder wire.
All fitted to the modified support plate and now in the tub.
Pedals also now in place.
On we go...
#23 Posted : 26 February 2021 18:16:05
Hi Roy
Very nice your skill's at it's best.
Trev
#24 Posted : 26 February 2021 19:48:01
Very nice work Roy. The dash with the gauges fitted look excellent.Love Love
#25 Posted : 27 February 2021 21:46:46
That's an excellent conversion job Roy and all very neatly executed too, well done. Cool ThumpUp
Kev.
kpnuts
#26 Posted : 28 February 2021 09:58:48
Superlatives are always in abundance in your builds mate, this is no different, that is pure awesome.
Nytetrain
#27 Posted : 28 February 2021 11:14:32
I am very impressed by how you changed the driver position from the left to the right. Flawless...
Best Regards,
Ron
In the Stash: Losing count...
#28 Posted : 28 February 2021 23:35:47
Incredible craftsmanship Roy. The conversion looks flawless.....Love Love
#29 Posted : 02 March 2021 15:45:08
Once again, I can only say thank you for all the very kind comments.
Not much to show today except the main engine/frame etc is fitted to the tub but there are a good few missing braces and tubes still to add.
On we go.
#30 Posted : 02 March 2021 23:27:44
Nice work Roy.Love Now you can start to see the size of this beast.
#31 Posted : 03 March 2021 14:35:16
Nice work Roy. Looking very impressive as always.BigGrin
#32 Posted : 04 March 2021 19:25:40
Keep it going Roy, its looking good.
I`m sure if something is missing you`ll have it replaced in no time.
Cool Cool Cool
#33 Posted : 04 March 2021 19:39:17
That's looking great Roy and certainly moving on at a good pace too. I'm sure this will be equally as good as the rest of your car builds when complete.
Very well done so far and keep it up. Cool ThumpUp
Kev.
#34 Posted : 11 March 2021 15:33:11
Many thanks for all the comments chaps...BigGrin
I've started on the body...
Interior is matt black, windows fitted and masked, door skins taped in place and all primed in grey.
There's logic in this apparently odd approach...
When it's all finished, I don't want joins at the lower body in front and behind the doors.
I'm going to spray the upper metallic grey, fit the interior parts required and then fit the body to the floor pan.
Then I'll sort out the join seams, rub them down, LOTS of masking, and then the blue sides can be painted in.
I'm hoping it will work.Confused
#35 Posted : 13 March 2021 21:50:59
After some fine sanding, I've sprayed the body metallic grey where it needs to be.
The body sides don't matter yet as they will eventually be blue...
#36 Posted : 14 March 2021 01:13:15
Lovely work as always Roy, making excellent progress.....Love Love
#37 Posted : 14 March 2021 10:47:00
Excellent build Roy Credit to you.
Trev
kpnuts
#38 Posted : 14 March 2021 11:06:10
Superb work mate.
#39 Posted : 14 March 2021 14:07:15
Thanks for looking in chaps.
Ok - masking tape removed, rear inner floor and subframe/suspension added and lower rear body in place.
A bit more to do on this section and then it will be fixed to the main floor pan.
#40 Posted : 14 March 2021 14:43:38
Very nicely done Roy. Looking excellent.Love Love
4 Pages <1234>
