Air Brush and compressor set Suggestions Wanted Options
Silent_Running
#1 Posted : 27 February 2021 11:55:57
Hi All,
I’m looking for an airbrush and compressor set, preferably sub £100. Can anyone suggest a decent set for me please? Also I’ve noticed the Badger set, what are the pro’s and cons of this layout.
Thanks in advance BigGrin
#2 Posted : 27 February 2021 13:56:36
Silent_Running wrote:
Hi All,
This is a bit over the £100 mark but is the sort of thing you need. Not a brand name I personally know, but has all the features you need.
Air tank, keeps pressure fluctuations to a minimum and saves wear and tare on the compressor.
Pressure adjustable (with gauge)
Moisture trap
Double airbrush holder
Pressure relief valve on tank
and two airbrushes
Copy and paste the ebay number into ebay search and you`ll see what I mean.
eBay item number:132166170957
#3 Posted : 27 February 2021 14:58:09
BigGrin Agree with Del here. Ive got the self-same compressor, and works just fine. You can adjust the pressure with the regulator, and the reservoir means constant spraying pressure.
With the airbrushes, you can always invest in better as your skill level with airbrushing rises. Personally, i dont like the syphon fed brushes. Much prefer the gravity fed (the one with the top-mounted metal cup, rather than under-fed plastic one).
However, be warned - you WILL end up buying different airbrushes for differnt jobs, bit like my wife does with her shoes LOL BigGrin LOL. I have 3. One for primer, one for everyday work, and another for clear coat to avoid cross-contanination.
Most importantly, practise a lot, and have fun with it BigGrin
Regards Gray
Nytetrain
#4 Posted : 27 February 2021 19:30:25
This is a good starter kit for your price range. I am not a big fan of siphon feed airbrushes. The are ok for laying down primer but that's about it. That is my own personal opinion though, others might disagree.
Ebay item number 143633181696
When buying a compressor make sure it has all the above mentioned features That Delboy stated. Most importantly is a tank and a pressure regulator.
Best Regards,
Ron
In the Stash: Losing count...
