Excellent work as usual Roy, looking fab as usual.....  .. Interesting to see how you're going about modifying the build to a RHD version. Finding it really inspirational for a newbie to plastic modelling like me....  Look forward to seeing the next steps..... Regards Alan
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,058 Points: 15,320 Location: ipswich
Many thanks you chaps. A bit more. The dash is now sorted with correct gauges, switch labels and bezels made from solder wire. All fitted to the modified support plate and now in the tub. Pedals also now in place. On we go... roymattblack attached the following image(s):
Joined: 13/02/2011 Posts: 2,239 Points: 6,837 Location: East Sussex
Hi Roy Very nice your skill's at it's best. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 6,864 Points: 20,909 Location: Northamptonshire, England
Very nice work Roy. The dash with the gauges fitted look excellent. Mark Regards Markwarren (Mark) Admin
That's an excellent conversion job Roy and all very neatly executed too, well done.
Kev.Per Ardua Ad Astra
Superlatives are always in abundance in your builds mate, this is no different, that is pure awesome. Ken's the name modeling's the game.
 Rank: Pro     Groups: Registered
Joined: 11/11/2015 Posts: 276 Points: 801 Location: Minneapolis, Minnesota USA
I am very impressed by how you changed the driver position from the left to the right. Flawless... Best Regards, Ron
On the bench: DeAgostini '67 Ford Shelby Mustang, Hachette Space Battleship Yamato 2202, Agora Models T-800 Terminator Finished builds: DeAgostini Toyota 2000GT In the Stash: Losing count...
Incredible craftsmanship Roy. The conversion looks flawless..... Regards Alan
Once again, I can only say thank you for all the very kind comments. Not much to show today except the main engine/frame etc is fitted to the tub but there are a good few missing braces and tubes still to add. On we go. roymattblack attached the following image(s):
Nice work Roy.  Now you can start to see the size of this beast. Mark Regards Markwarren (Mark) Admin
Nice work Roy. Looking very impressive as always. Malc.
Keep it going Roy, its looking good. I`m sure if something is missing you`ll have it replaced in no time. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
That's looking great Roy and certainly moving on at a good pace too. I'm sure this will be equally as good as the rest of your car builds when complete.
Very well done so far and keep it up.
Many thanks for all the comments chaps... I've started on the body... Interior is matt black, windows fitted and masked, door skins taped in place and all primed in grey. There's logic in this apparently odd approach... When it's all finished, I don't want joins at the lower body in front and behind the doors. I'm going to spray the upper metallic grey, fit the interior parts required and then fit the body to the floor pan. Then I'll sort out the join seams, rub them down, LOTS of masking, and then the blue sides can be painted in. I'm hoping it will work. roymattblack attached the following image(s):
After some fine sanding, I've sprayed the body metallic grey where it needs to be. The body sides don't matter yet as they will eventually be blue... roymattblack attached the following image(s):
Lovely work as always Roy, making excellent progress..... Regards Alan
Excellent build Roy Credit to you. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Superb work mate. Ken's the name modeling's the game.
Thanks for looking in chaps. Ok - masking tape removed, rear inner floor and subframe/suspension added and lower rear body in place. A bit more to do on this section and then it will be fixed to the main floor pan. roymattblack attached the following image(s):
Very nicely done Roy. Looking excellent. Mark Regards Markwarren (Mark) Admin
