10 Pages 123>»
Sean's HMS hood Options
S2ksean
#1 Posted : 16 September 2011 15:44:03
First 3 issues
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
S2ksean
#2 Posted : 16 September 2011 15:48:39
Issue 1 I had to improvise
Issue 1 is complete now on to issue 2
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
willie
#3 Posted : 16 September 2011 16:59:02
a tip watch out when useing the spare wood as an right angle you will find out that they are not 90 deg angle
S2ksean
#4 Posted : 16 September 2011 17:02:28
Thanks for the tip I did check it to make sure before I started
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
willie
#5 Posted : 16 September 2011 17:08:26
dont mix then up best to mark it,i tried that then found out it was not square after not this build but the last trial
S2ksean
#6 Posted : 16 September 2011 17:27:37
Cheers willie I've checked it and now I've marked it so I no which corner I'm using this is my first ship build so all advice is welcome.
Issue 2
Issue 2 done now onto issue 3 :)
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
S2ksean
#7 Posted : 16 September 2011 18:23:29
Issue 3
So far so good no problem so far all bolted down awaiting issue 4. Although ive only done to issue I already really enjoying this build I might have to do another as an in between build thinking of the black pearl still lol
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
Tiswas
#8 Posted : 16 September 2011 18:39:47
Looking good so far Sean, keep up the good work.
TIS
#9 Posted : 16 September 2011 19:09:10
Sean nice clean build, good stuffCool BigGrin
S2ksean
#10 Posted : 16 September 2011 21:14:28
Cheers tis and mwg be nice when the hull skeleton is done. By the Way does anyone no when that will be?
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
#11 Posted : 16 September 2011 21:21:04
I notice your using superglue for the hull framework, you should be using PVA glue for the static and a waterproof PVA or Aliphatic resin for the R/C version Wink
S2ksean
#12 Posted : 16 September 2011 21:31:31
Will it make much ov a difference T?I plan to r/c it and didn't think it would matter as it's going to all be water proofed inside with maybe fibre glass. I thought superglue would have been better/stronger for this.
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
willie
#13 Posted : 16 September 2011 21:48:26
super glue gives you one chance the glue i am useing is NO MORE NAILS EXPRESS pva is weather proof gives a strong bond in 5 to ten minutes full cure in 24 houres and its cheaper than super glue
#14 Posted : 16 September 2011 21:48:47
By the looks of it the superglue you have is the run of the mill thin stuff, which soak's into ply like water and gives a very weak bond, it would not have been so bad if you had used a thick superglue.
Give the frames and all the woodwork a wiggle, where you might find some pull loose; superglue gives a bittle bond, but if all is okay, from here on in use a waterproof PVA.
For R/C, the wood to wood parts such as framework and hull planking use a waterproof PVA such as the EVO stick blue bottle version which is about the best or use Aliphatic Resin glue if you are to avoid risk of water ingress into joint problems.
I bet many make this mistake Crying
budgie
#15 Posted : 16 September 2011 21:49:30
Blushing Hi s2ksean,i know of 1 advantage over pva/super glue due to my own errors is that if u need to remove a wooden part that is not to your satisfaction this can be done quite easily by soaking the joint and making the pva glue soft therefore easy to remove
I doubt very much if you could do that with superglue
S2ksean
#16 Posted : 16 September 2011 21:51:29
Do u think it would be ok if I went over all the joins with a better glue?
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
S2ksean
#17 Posted : 16 September 2011 21:55:17
Ur not wrong budgie I just checked it and all the joins are solid. So far I haven't made any mistakes (appart from using the wrong glue lol) so I haven't had ta move/change/adjust anything.
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
#18 Posted : 16 September 2011 21:56:22
I am using Aliphatic, I will also brush adhesive into the joints, just for more strength, as we did on the Victory, and guys MR T is always right mutter!! mutter!! makes you sick!!!!!!!LOL
#19 Posted : 16 September 2011 21:56:40
Personally I would check every wood part, remove any you can and reset with a waterproof PVA, those that remain fast, brush a small fillet of glue into the joints so at least its seals the joint.
I'm surprised the instructions do not state at the outset to use a waterproof PVA for the R/C build.
S2ksean
#20 Posted : 16 September 2011 22:00:35
Thanks mr t I appricate the help I will do and il post the pics as I go so peeps can help me cause it prob won't be the last time I make a mistake on this build lol
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
10 Pages 123>»
This page was generated in 0.437 seconds.
