Marking out the transverse lines (magazine no 35) Options
Dinadan
#1 Posted : 23 February 2021 00:53:13
When marking these out (and also the gun ports) do you measure the vertical height or lay the ruler against the side of the hull so it is at an angle to the vertical please?
#2 Posted : 23 February 2021 01:37:31
Hi Chris, now this is what I would say is a really good question, simply because the instructions don't give any indication nor has there been a definitive answer on it that I can find. All I can say is that on my build I went with measuring on the vertical and for me it worked out.....Cool Cool .. Not the definitive answer you're looking for but the best I can give I'm afraid..... Others may have measured following the profile of the hull but nobody that I can see has said they've done it this way.....Cool Cool
This page was generated in 0.169 seconds.
