 Rank: Beginner Level 1 Groups: Registered
Joined: 25/04/2018 Posts: 7 Points: 21 Location: Kent
When marking these out (and also the gun ports) do you measure the vertical height or lay the ruler against the side of the hull so it is at an angle to the vertical please?
Hi Chris, now this is what I would say is a really good question, simply because the instructions don't give any indication nor has there been a definitive answer on it that I can find. All I can say is that on my build I went with measuring on the vertical and for me it worked out.....  .. Not the definitive answer you're looking for but the best I can give I'm afraid..... Others may have measured following the profile of the hull but nobody that I can see has said they've done it this way..... Regards Alan
