4 Pages <1234>
Dolls House Options
Mustang
#21 Posted : 21 February 2021 00:05:20
Thanks skyfire, as you've done one of these types of house you know there not great.
Built:-. HMS Bounty, RMS Titanic, MP4-23, Flying Scotsman, Aston Martin DB5, Honda CB750, Mustang, R2-D2, Jaguar, DeLorean, Testarossa, Stage Coach plus many plastic kits.
Dry dock no room to display:-. Bismarck, U96.
To build:-
. HMS Hood. HMS Victory. Cutty Sark. SoS, Lancaster bomber. DR1 Triplane. JU-87. Plus many many plastic kits.
Mustang
#22 Posted : 21 February 2021 00:10:09
So on with the build, the roof isn't that well put together. There no real strength in the corners of the joints just ply against ply Bored Blink
Here is how they would have you put it together.
The side wall sitting on the inside edge of the roof, ok that seams ok.
Except they didn't allow for the hight difference when they did the but joints.
Which put the walls out of alinement.
To build:-
Mustang
#23 Posted : 21 February 2021 00:15:04
So my first idea is this...
Add a piece of wood to the bottom of the wall.
Which allows the walls to aline correctly.
And seams to all be level, well level-ish..
And with the roof sections added. Which by the way are twisted... So I steamed them today and put them under some heavy books.
To build:-
Mustang
#24 Posted : 21 February 2021 00:19:39
But this then gives me another problem...
The front sections would then be to short.
So, do I do it this way and add a strip along the bottom which I could hopefully hide when I cover the roof with the cardboard tiles, or do I cut the rear sections down 2-3mm so the aline with the side walls with out the piece of wood Mellow but this could cause the rear wall sections to then be to narrow left to right and end up with them not sitting in the centre support at the rear.
To build:-
Mustang
#25 Posted : 21 February 2021 00:26:24
So while my mind was trying to work out what might be best I carried on with the main house.
The moulding added around the top and centre of the house.
Now when I got these parts I didn't have 100% all the parts i.e I was missing the front long mouldings but I had spare short ones.
So I mitred the joints to allow a better join.
A little filler and done.
To build:-
Mustang
#26 Posted : 21 February 2021 00:32:54
Next up was fitting the front sections, I wasn't looking forward to this as fitting hinges isn't my strong point but they went on fine.
Now they have you fit the hinges straight to the main frame thats fine. but they have you add a piece of wood to the inside of the front wall to allow for the screws, this seamed stupid to me as it would mean the front sections would stand well away from the house.
So I screwed mine straight to the house and to the front sections but added a piece of wood to the outside of the house. Sorry forgot to take a photo but you'll get the idea next.
This also meant the distance between the front section and the house was less with meant I could fill it with a piece of wood.
Before.
After with a piece of the wood I was meant to glue to the hinge.
To build:-
Mustang
#27 Posted : 21 February 2021 00:36:24
Now there was a small gap in the front sections...
So again I added a piece of wood.
All four sections added.
To build:-
Mustang
#28 Posted : 21 February 2021 00:41:25
next was the front door, I couldn't get the kit door I only had the front outer section so that wasn't worth adding so I decided to use one of the doors Brought for inside as I had some spares.
This of course meant the cut out wasn't correct so once I had the door in place I cut out and added some piece from the cut out piece and added them top and bottom.
The top section was something I made.
To build:-
Mustang
#29 Posted : 21 February 2021 00:45:19
So I'll go round the it tomorrow wood filling here and there, then I just need to wait for a nice day outside so I can give it a good sanding down.
I'll also start the side extension and the other little pieces.
To build:-
skyfire
#30 Posted : 21 February 2021 10:34:24
Publisher Medal: Featured Build of the MonthActive Service Medal: 500 post active service MedalBuild-Diary Medal: Build-Diary Medal of HonourRed Medal: Red Medal
Don't think I had these sorts of problems with my one. Knew I should have taken more photos while I was building mine.
Your doing well Mustang. :)
Mustang
#31 Posted : 21 February 2021 11:27:25
Hi skyfire, looking at yours that you did you had the other version from del prado as I know they did three different releases.
Green book version.
Red book version. I think that’s the one you did
Blue book version. That’s the one I’m doing
To build:-
skyfire
#32 Posted : 21 February 2021 11:45:38
From memory, it was the first one released by Del Prado. I built it back in 2008.
I did the red book version, I knew there was another one, after the one I built, but I didn't know about the other one. :)
#33 Posted : 21 February 2021 16:43:32
Coming on very nicely.Love Love Looks like it certainly got those grey cells working.LOL
Mustang
#34 Posted : 28 February 2021 22:52:41
Hi Guys thanks for popping in.
So update, between this and my cross stitching its been busy Blink Blink
I worked out my little issue with the roof so thats all done except I just need to glue the top sections on and then the front sections with the hinges which again problem as the way they have them is stupid but I'll show what I'm doing later once there on.
So house with side section.
The roof is still loose so I can paint the inside frames.
To build:-
Mustang
#35 Posted : 28 February 2021 22:54:06
I'm adding a light to this section and wanted to hide the cable so....
From this
To this
To build:-
Mustang
#36 Posted : 28 February 2021 22:55:14
And so I did the same with the rest of the summer house.
To build:-
Mustang
#37 Posted : 28 February 2021 23:00:02
And the rooms completed so far.
Kitchen
Dinning/Living Room
Bath Room
Living Room/Main Bed Room
Study
Kids Room
Summer House not complete still need top section adding
To build:-
skyfire
#38 Posted : 01 March 2021 10:51:07
Your going well. Love the detail in the rooms so far. :)
goddo
#39 Posted : 01 March 2021 11:09:44
It's fascinating to watch this build.
I bought a kit (can't remember which one) from a now extinct model shop in Amersham many years ago just after my first daughter was born. I spent many hours building and decorating that. Really enjoyed it. So did my daughter fortunately. It's still in the loft now (waiting for a grand daughter who will play with it.)
Will watch your progress with interest.
Mustang
#40 Posted : 02 March 2021 18:13:58
So the roof section is all finished.
But a small hiccup has come up, the kit comes with two windows for the upper section.
But I have a spare one.
So two or three windowsConfused Confused Confused
To build:-
4 Pages <1234>
This page was generated in 0.313 seconds.
