Joined: 23/09/2018 Posts: 154 Points: 471 Location: Cape Town
progress on the cut out... Roeland attached the following image(s):
I decided to show the capstans in the cut out - all in the back ground.The picture shows the rudimentary capstans. Roeland attached the following image(s):
I added some columns and "coriander" cannon balls. Roeland attached the following image(s):
Making beautiful progress there Roeland, she's looking superb....  . The extra detail you're applying makes a great deal of difference..... Very well done.... Regards Alan
Joined: 29/03/2011 Posts: 1,053 Points: 3,165 Location: Glenvista JHB
Nice work Roeland. I like the way you have treated the cutout. The transition from planking through ribs really works well. Kind regards, Garth "Measure twice, cut once!!!" Finished!!! HMS Victory, Current build: Black Pearl. On hold: Bismarck, Golden Hind, Flying Scotsman, Victory Cross Section, SOTS, Tiger 1. Wish list: USS Constitution.
Playing around with a entire gun crew for a 24 pounder. It looks to busy inside the hull - perhaps a consideration for the quarter deck.... Roeland attached the following image(s):
Maybe like this on the quarter deck - starboard side? Roeland attached the following image(s):
 looking good 👍. Guns on the Victory had a crew of five plus a quarter gunner who looked after four guns that made sure they had enough shot and charges .Hope this helps Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Joined: 28/05/2014 Posts: 82 Points: 248 Location: London
Great build, Its coming along very nicely!
Martyn Ingram wrote: looking good 👍. Guns on the Victory had a crew of five plus a quarter gunner who looked after four guns that made sure they had enough shot and charges .Hope this helps Martyn Hi Martyn, I based my information on the "Haynes HMS Victory" in which it states that firing a 24 pounder from one broadside requires a crew of 12 - however firing from both sides only requires a crew of 6 for each gun. I thought the crew was moving between guns....I don't know if this is correct?
The first "cut out" 32 pounder gun is in place and rigged. Roeland attached the following image(s):
Excellent!! Coming along nicely. Very envious of your skills. Chris
goddo wrote:Excellent!! Coming along nicely. Very envious of your skills. Chris Thank you - after more than 3500 hours skill seems to improve.
Excellent work.  you must have only been 21 when you started this. Mark Regards Markwarren (Mark) Admin
Markwarren wrote:Excellent work.  you must have only been 21 when you started this. Mark I actually build my first model earlier - probably around 8 years old. But as it goes live takes over and if it was not for the fact I got retrenched and took early retirement I would not have the time to indulge in this model. The 3 x 32 pounders are now in position. Roeland attached the following image(s):
Looking fab Roeland, very nice progress indeed.... Regards Alan
Hi Roeland That`s a very tidy piece of work. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
A dry fit of the 32 pounders and figurines. Roeland attached the following image(s):
To allow views of the upper gun deck I decided to hoist in the launch. I had to use a bit of imagination as there is very little available on this subject matter. To avoid too many crew on the deck I decided that the yard and stay tackles would be hoisted in from middle deck; using the capstan.I will still add supports for the yard from the top pendants and the guy ropes will be guided from the quarter deck. The imaginary scene would depict a tactical retreat - with boats hoisted and guns fired at the enemy. Roeland attached the following image(s):
I started adding some figurines to the hoisting of the launch. Roeland attached the following image(s):
