56 Pages «<56789>»
willie
#121 Posted : 15 September 2011 12:58:03
mwg i thought you might like a look at this boats speed controllers from HONGKONG £16-50p for the two 110amp forward 40 am reverse i know there high rated but at that price i have speed controller fitted to one of my submarines from HONGKONG and workes great
#122 Posted : 15 September 2011 19:06:55
Thanks for that WillieBigGrin Cool
willie
#123 Posted : 15 September 2011 20:44:48
that ok forgot to say the picture of the speed cont' are just about size of them if you have a 19" screen
#124 Posted : 15 September 2011 23:25:08
Cheers WillieCool
#125 Posted : 16 September 2011 08:59:32
A LITTLE TIP
When you are joining the false keel parts together, I believe its useful
to unscrew the boat from your build board,clamp the pieces together and wait untill the adhesive is dry before screwing the hull back down on your board.
If you don`t there is a danger the hull will stick to the board with adhesive seeping through the join.Wink Cool
Zeptrader
#126 Posted : 16 September 2011 16:09:32
very good tip, cheers for that, obvious to some but worthy of a 'tip of the day'.
willie
#127 Posted : 16 September 2011 16:46:06
or put masking tape on the other side of the joint the glue wont stick to it because of its own glue this can be used buy anny type of glue even super glue
Tiswas
#128 Posted : 16 September 2011 18:42:32
Two useful tips worth remembering. Well done guys.
TIS
#129 Posted : 16 September 2011 19:05:39
Thanks ColCool BigGrin in ,cheers Willie
#130 Posted : 16 September 2011 19:12:03
Cheers TisBigGrin Cool
Dontshootme
#131 Posted : 17 September 2011 10:04:34
Another way is to cover the board with cling film,that way you just peel it off when all gluing has been done.
#132 Posted : 17 September 2011 11:34:41
Another good tip RobThumpUp
#133 Posted : 19 September 2011 18:26:12
Hi everyone I will be away on holiday from tomorrow 20th Sept untill 28th Sept.
Speak when I get backCool BigGrin
S2ksean
#134 Posted : 19 September 2011 22:47:01
Happy holidays mate
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
#135 Posted : 19 September 2011 22:49:48
Cheers SeanBigGrin Cool
#136 Posted : 28 September 2011 16:52:36
Well I am back off my hols, had a great time and came back to a heat wave, can not be badBigGrin
ISSUE 4
I sat outside today and completed parts 4 and 5 thats the beauty of this hobby you can enjoy it any where.
I cut out all the pieces, sanded them:-
#137 Posted : 28 September 2011 16:55:21
Then I put them together, as per the instructions ( which I must say a beginner would find this build a dream)
#138 Posted : 28 September 2011 16:57:39
As you can see the sun is fabulousBigGrin
#139 Posted : 28 September 2011 16:59:46
ISSUE 5
This is much of the same I cutout all the pieces and sanded them:-
#140 Posted : 28 September 2011 17:01:20
Then I put the parts together as per the instruction:-
Guest (15)
56 Pages «<56789>»
This page was generated in 0.427 seconds.
