3 Pages 123>
Pocher Fiat - Phoenix from the ashes Options
#1 Posted : 06 February 2021 15:55:43
Although I did this a while ago, I thought I'd post it up as it's a wee bit quiet on the forum at present
It's an ancient Pocher kit of the Fiat F2 race car.
I acquired it long, long ago as a total broken wreck. A good few parts were missing and some parts literally in a dozed pieces. To make it worse, it had been consigned to an open cardboard box in a garden shed for around 10 years.
I decided that if the old girl was going to survive it would have to be total dismantling project with all the parts washed, labelled and put into boxes/bags so I would know where bits were upon an eventual rebuild.
I downloaded the build manual from a Pocher website and made a start taking it all to pieces...
#2 Posted : 06 February 2021 21:26:56
OMG Roy,Blink Blink
You don`t do things by half or the easy way.
Will be intrigued to see what you made of this, even if it was some time ago.
#3 Posted : 07 February 2021 10:44:25
Looks like an episode of Car SOS.LOL Looking forward to see what restoration you can give the old girl.
#4 Posted : 07 February 2021 18:08:41
This will be fun to watch Roy and a great subject - I love those vintage/veteran race cars!
I'm sure that you'll turn out a nicely restored model at the end of this project. Cool ThumpUp
Kev.
#5 Posted : 07 February 2021 20:00:58
Many thanks for looking in chaps, and the comments.
The first bit of 'reconstruction' involved cleaning up the engine parts, removing huge globs of ancient glue - it almost seemed like Evo-Stik.
The separate parts were scrubbed, dried, cleaned up and finally repainted. I also started adding the multitude of missing oil pipes and other small details. The two silver bands over the magneto were also scratched from paper clips as they are missing from the actual kit.
On we go...
#6 Posted : 08 February 2021 12:04:36
Nice work Roy, looking good and well on the way to another fine restoration project from you. I like the use of the paper clips and the real copper wire/pipes, very effective.
I've never built a Pocher kit in my many years of modelling, but I can see that they are well worth an attempt at building one someday, and if I did, this would be high on my list as I love old racing cars. Great to see that you still have the original metal drive chain in the box, that would have been a nightmare to scratchbuild!! Blink Blink
Here's a link to a nice build of this very same kit, which might be useful reference for you Roy:
https://www.britmodeller...088292-pocher-fiat-f-2/
Well done so far.Cool ThumpUp
Kev.
kpnuts
#7 Posted : 08 February 2021 17:35:56
Off to a great start mate
#8 Posted : 10 February 2021 12:01:48
I've only just spotted this. Apologies Roy.
Great restoration project, really nice work with the piping. This is going to be good to follow.BigGrin
#9 Posted : 16 February 2021 15:28:45
Some more on the old Fiat.
The radiator was just a solid lump of plastic so I cut the centre out and made it from wire mesh. I made a stencil of the 'F-2' in masking tape, applied it to the mesh and then painted it matt black. I was quite pleased how it turned out.
Next, I turned to some of the gearbox parts which were cleaned up, repainted and reassembled.
The front beam axle was actually broken it two so I drilled the broken ends and glued a brass rod in place, then epoxied it all back together.
The fuel tank was cleaned up and repainted next.
Then came the floor. A total broken mess of brown plastic parts. I decided to replace it all with real wood.
On we go...
#10 Posted : 16 February 2021 19:07:13
Very nice restoration. I like that wooden flooring.
#11 Posted : 16 February 2021 20:18:33
Coming on nicely Roy, the wooden flooring is going to look so much better than the old plastic part.Love
#12 Posted : 18 February 2021 15:40:21
Very nice work all round Roy, great finish on that red paintwork and the real wooden floor is set to make all the difference to the look of the finished model, much better than the plastic part and well worth the extra effort involved.
Well done, good job! Cool ThumpUp
Kev.
#13 Posted : 18 February 2021 17:54:46
Luv the old style engines with all the brass pipes and stuff. Amazing engineering for the time.
Looking forward to the next update.Cool Cool
Nytetrain
#14 Posted : 18 February 2021 18:24:47
I love these Pocher kits. They have so much detail and look great. I have been looking for one to build in the near future but the older kits are hard to find. Even the new kits are rare right now.
Best Regards,
Ron
In the Stash: Losing count...
#15 Posted : 21 February 2021 01:02:07
Simply beautiful Roy, love the idea of the wooden flooring... we'll get you working with wood yet.....LOL LOL .. If you give that wood a couple of coats of Danish Oil it will really make the grain pop..... Just a thought.....Cool Cool Cool
kpnuts
#16 Posted : 21 February 2021 09:46:15
Great work roy, yep you can't beat real wood over plastic.
#17 Posted : 21 February 2021 12:00:45
As before everyone - Many thanks for looking in and the very kind comments.
The dash/scuttle was wood-trimmed next and then the frames were assembled along with fitting the fuel tank. Next to go in was the engine and radiator.
The scuttle and floor were then added.
All going quite well so far.BigGrin
#18 Posted : 21 February 2021 16:37:42
All coming along very nicely Roy. Love Love Certainly looking very different from before.
#19 Posted : 02 March 2021 16:00:14
Thanks Mark. Much appreciated.
Next - cleaning up, repairing splits in the plastic and then painting the seats and seat supports. All pretty straightforward.
The gearbox etc was then added underneath, and some of the fuel pipes cleaned up, polished and then fitted.
One of the leaf springs had a moulded plastic section completely snapped off and missing.
I pressed the remaining part into a block of Plasticine and cast a new piece in resin. Once fitted, it was fitted to the axle along with its partner after they were all bound with cord as per the real car...
kpnuts
#20 Posted : 02 March 2021 18:48:44
She's looking very impressive
3 Pages 123>
This page was generated in 0.570 seconds.
