11 Pages «<91011
1:24 Smokin Dragster ( Another Stage Closer) Options
#201 Posted : 23 January 2021 18:42:17
tigerace wrote:
Any update Derek Confused
Regards PhilCool
Hi Phil,BigGrin
Hope to have an update soon. Been having trouble with a lack of grip on my left hand due to tendon problems with the thumb. Physio has helped, but may need minor surgery to improve things further. When that may happen with the present state of things I don`t know.
My wife is still awaiting cataract surgery that was cancelled three days before the first lockdown in 2020, so I`m definitely not holding my breath.
Thanks for looking in anyway.Cool
#202 Posted : 23 January 2021 18:58:29
I'm looking forward to an update on this one too...
Don't keep us in suspense.LOL
kpnuts
#203 Posted : 24 January 2021 13:19:58
Ditto
#204 Posted : 02 February 2021 23:59:19
Hi All,BigGrin
Apologies for the delay in this update, but my left thumb is spending a lot of time in a splint at the moment with tendon issues.Crying
Enough whingeing Blushing Blushing
So where was I ?
Pic 1: shows the balsa prototype from previous post.
Pic 2: shows a heavy weight table vice I bought of Ebay to help hold things I am working on. Thanks to Alan (Gandale) for the heads up on that one.
Since then I have purchased some blocks of Mahogany to make the gearbox sides for the final item. I`m using Mahogany to reduce wear and tear on the walls when the mechanism spins.
Pic 3: shows the side walls prepped and the red arrows show where spacers are needed to hold the walls the correct distance apart.(3.5mm)
Pic 4: shows the gearbox set-up (not glued) so I could work out the size of spacers required between the walls.
Pic 5: shows the whole gearbox clamped up, with the spacers in place. This is still not glued up, but will allow me to take all the necessary measurements I need to work out the height of the dio base above all the workings underneath.
This measurement will be critical as the gear showing top left in the final picture will have to engage the gear on the cars back axle through a slot in the dio base.
Also, I have recently purchased a job lot of Meccano (waiting delivery) that I will be using as support bracing for later parts under the dio base. (More on that at a later time).
Well that`s it for now. Next update ASAP.
#205 Posted : 03 February 2021 12:59:30
Wow Derek.Love Love That is some work you’ve done. Love Cool
Looks like that weren’t the only cogs going, working all that out.LOL
Great work
#206 Posted : 03 February 2021 22:16:15
Wow.you made your own gearbox.Cool. Cant wait to see this finished
#207 Posted : 04 February 2021 00:02:10
Hi All, BigGrin
Thanks to Mark and Carl for your comments and for the others who looked in.
Reference the gearbox, it was quite easy as the prototype was made in balsa. All I had to do was push the axles into the balsa and if wrong just move the position slightly. No drilling and filling holes and when the correct position was found take the measurements needed and transfer them to the mahogany.
Next job is to make the sides that will support the dio base. The measurements for this will be decided by the height of the gearbox when placed on the electronics base. This is where the fun will start, as then I have to get everything that will be on top of the dio base lined up with all the workings underneath.
Well more on that at a later date.
Until then, HAPPY MODELLING and STAY SAFE.BigGrin BigGrin
#208 Posted : 04 February 2021 15:43:23
Well done Derek looking good, great bit of scratch work.
Trev
#209 Posted : 04 February 2021 16:58:15
Trev
Thanks for looking in and the comments Trev, much appreciated.
#210 Posted : 04 February 2021 20:48:34
Great to see you back on this Derek and moving it forward. Looking really good and I'm so impressed with how you're putting together the various drives and motors that will bring this all to life at the end. Well done. Cool ThumpUp
Hope your thumb isn't causing you too much trouble.
Kev.
#211 Posted : 04 February 2021 21:07:34
Kev.
Hi Kev,
Always appreciate you looking in and your comments.
Everything in this build comes from those dark corners of my head, go down on paper and then get modified (sometimes several times) before they get built and work. LOL LOL
The thumb (thanks for asking) is spending more time in a splint, but the physio exercises and me gritting my teeth from time to time is keeping it useable. Just.
#212 Posted : 15 September 2021 11:02:25
Any update DerekConfused
Regards PhilCool
#213 Posted : 15 September 2021 16:01:33
Regards PhilCool
Hi Phil, BigGrin
While I`ve got more daylight hours and some decent weather I`m working on my 1:1 scale cruiser, but this and others will be back on the boards as soon as possible.
Thanks for the enquiry.
#214 Posted : 15 September 2021 19:48:43
Looking forward to seeing updates here...BigGrin
#215 Posted : 16 September 2021 11:07:19
delboy271155 wrote:
Regards PhilCool
Hi Phil, BigGrin
Thanks Derek looking forward to seeing moreDrool Drool
Regards PhilCool
#216 Posted : 17 September 2021 13:41:36
It will be nice to see more updates on this cool build Derek and I'll look forward to seeing what you do with it once you're done with all of that 1:1 boat building?
Almost makes me wish the days would become shorter and the nights become longer sooner than they ought to, just to see more of this! BigGrin ThumpUp
Kev
11 Pages «<91011
This page was generated in 0.185 seconds.
