25 Pages «<1314151617>»
Goddo's Build Options
goddo
#281 Posted : 07 December 2020 16:52:02
A couple more update pics. A bit hazy for some reason...sorry.
goddo attached the following image(s):
goddo
#282 Posted : 22 January 2021 17:27:17
I know I posted similar shots of the bow recently but it only came to my notice today that the keel is looking twisted. I have attached another couple of shots for your comments, please.
Is this going to cause problems at a later date in the build. I seriously hope not because its a lot of dismantling if I have to do that.
Sorry, forgot to change the image extension.Blushing
z8000783
#283 Posted : 22 January 2021 17:28:57
Groups: Unapproved
If you've go this far, Chris, this is later.
goddo
#284 Posted : 22 January 2021 17:30:36
Sorry John, I don't quite understand what you are saying.
z8000783
#285 Posted : 22 January 2021 17:32:18
Groups: Unapproved
I'm not sure what is going to happen from this point on that would be a problem beyond what you can see already.
#286 Posted : 23 January 2021 00:48:30
From what I see Chris, you have managed to get this far without encountering any real problems. With a twisted keel the biggest problem you would have come across would have been apparent when fitting the gallery. She's really is looking fab and a strip back is not an option to be taken lightly considering the progress you've made, in fact is not an option I would take. What I would ask you to do is to temporarily fit the masts and bowsprit in place, then take a series of pics from bow to stern and stern to bow. This will give you an idea how it will all line up. Also, how do you intend to display the build, ie, will it be viewed side on or from the bow?
Look forward to seeing the pics....
eebygum
#287 Posted : 23 January 2021 08:42:37
What an excellent looking build superb. Well doneBigGrin BigGrin BigGrin
goddo
#288 Posted : 23 January 2021 12:27:35
Hi All, thank you for taking the time to take a look and comment.
A good idea of Alan's to put the masts and dummy bowsprit on to see how everything aligns.
I'll do that later and take a few shots of her.
Perhaps you would be good enough to have another look for me.
I must admit that I haven't given display options any thought until now. I guess it will depend on which side turns out to be the most acceptable. Blushing Blushing
goddo
#289 Posted : 24 January 2021 12:54:36
I took some pics of the model with the masts temporarily in place.
Unfortunately, they wouldn't remain in their correct positions while I was taking the shots.
The bowsprit isn't made up yet so I just inserted the dummy stem from earlier in the build.
Oddly enough, the distortion of the keel doesn't look so alarming when this is fitted. Blushing Blushing
Would appreciate any comments about the keel distortion (Or am I being over concerned?)
You can definitely see the twist in the third pic.
z8000783
#290 Posted : 24 January 2021 13:06:05
Groups: Unapproved
TBH I still can't see anything worth worrying about. The build itself is wonderful with stacks more to add that I don't believe will highlight any distortions more than it has so far. In fact they will take the eye away from it.
The alternative is to think about what you will need to do at this point, to achieve the outcome you are looking for. In other words, the cure could be worse than the disease.
nightwisher
#291 Posted : 24 January 2021 18:24:59
Looks pretty good to me. If there is a twist it's only a very slight one and if need be the masts can easily be adjusted to all line up. If it was my build there's no way I would strip it back
Had a dream to understand
A single grain of sand
He gave birth to poetry
But one day will cease to be
leedsfromsouth
#292 Posted : 24 January 2021 19:16:48
Looks pretty good to me , sometimes we look to hard for problems..
z8000783
#293 Posted : 24 January 2021 19:19:08
Groups: Unapproved
Ha ha, I have found over the years that I don't have to look very hard at all . . .
#294 Posted : 24 January 2021 22:05:19
From what I see Chris I certainly wouldn't contemplate any amount of stripping back, can't see anything to be worried about. If I were you I would simply carry on.... Looking fab.....Drool Drool
goddo
#295 Posted : 24 January 2021 23:05:07
Thanks for taking the time to have a look and comment.
As I said earlier, once I put in the dummy bowsprit and "stood back a bit" things didn't look as bad as I thought originally.
No stripping back and just carry on then. Thanks again.
#296 Posted : 24 January 2021 23:06:43
I'm no expert, but it looks just great to me. I think you only see it because you know it's there. To the layman they just see a superb build ThumpUp
Gray
goddo
#297 Posted : 25 January 2021 03:00:42
Many thanks to John, Alan, eebygum, night wisher, leedsfromsouth and CaptBirdseye for commenting and offering kind words of encouragement. It means a lot.
My "twisted keel worry spell" is over and I'll continue with the build as it is.
Thanks again. Happy modelling.
#298 Posted : 28 January 2021 07:55:42
Hi Chris,
I think your build looks fantastic!!!
I am glad that you have decided to overlook the issue. Once all the rigging is done and she is in a display case - none will be the wiserBigGrin
goddo
#299 Posted : 30 January 2021 11:34:54
Garth wrote:
..... and she is in a display case.....
Thanks for your kind comments Garth.
But therein lies a bit of a problem. I haven't even thought about a display case yet and the model is already getting very dusty. I keep brushing off what I can but once I start adding the rigging, I can see a big build up of dust and bees wax among other things. I did buy one of those bulb air "puffer" things which it isn't very effective. I don't own a compressor so that idea doesn't work for me. Does anyone have any tips on keeping things clean(er)?
Roeland
#300 Posted : 30 January 2021 14:08:26
Did you try a hairdryer on cold air or a blower? I also use a soft paintbrush for the dusting.
This page was generated in 0.253 seconds.
