 Rank: Pro  Groups: Registered
Joined: 24/01/2011 Posts: 206 Points: 614 Location: halifax
hi fellow builders im just starting on issue 45 the destructions say use a strip of 1 x 6mm wood for the deck supports question is which issue do they come in i cant find them in any oft he packs i have already opened
Its a misprint at step 4, the size is 1.5x6mm as per the strips supplied in 45 (noted in the parts list as 1.5x6mm)
Tomick wrote:Its a misprint at step 4, the size is 1.5x6mm as per the strips supplied in 45 (noted in the parts list as 1.5x6mm) cheers mr t, am i missing some thing but 5 planks dos't seem enough to do the whole of the lenth of the ship
In 44 you should also have five 1.5x6mm strips = 10 and is enough to complete the deck beams in 45, also says the same in my diary build for 45 http://forum.model-space....aspx?g=posts&t=1846
