10 Pages «<56789>»
Roeland Options
goddo
#121 Posted : 08 January 2021 20:06:21
All looking very good, Roeland.
#122 Posted : 08 January 2021 23:23:40
Very neat and tidy building.
Hope it all continues well for you.
Roeland
#123 Posted : 10 January 2021 13:27:51
I added home made oars, anchor and boat hooks.
Roeland attached the following image(s):
#124 Posted : 10 January 2021 14:27:07
Very nicely done as well.
Roeland
#125 Posted : 13 January 2021 16:05:41
The barge is now complete.
Roeland
#126 Posted : 17 January 2021 17:33:31
4 boats finished - 2 to go
#127 Posted : 21 January 2021 11:51:45
Hi Roeland,
The small boats are looking fantastic.
#128 Posted : 23 January 2021 00:11:28
Beautiful work with the ships boats, very nicely done.....Drool Drool
Roeland
#129 Posted : 23 January 2021 17:18:03
I got a bit crazy - making the kedge anchor out of a tooth pick - progess
Roeland
#130 Posted : 27 January 2021 10:49:41
A bit of a disappointment - I only received 45 figurines and no Nelson, Hardy and Thomas?
Roeland
#131 Posted : 27 January 2021 14:19:13
I have now positioned the port side 25 ft cutter and made progress on the starboard side cutter. After making 6 of these small boats the quality is improving - I'm starting to get the hang of it.
Roeland
#132 Posted : 28 January 2021 14:55:21
I provisionally positioned the cutter and 8 figurines (before painting) on star board side. I'm not sure how many people would be used to hoist the cutter; I allowed for 4 but imagine it would be many more. The other 4 figurines will be off-loading the oars - also not sure if this is correct?
Roeland
#133 Posted : 29 January 2021 15:46:46
All painted and in position. PS - the kedge anchor is also in position - hardly visible.
goddo
#134 Posted : 29 January 2021 18:05:36
Roeland,
Terrific detailing on those figures and lots of imagination.
I love the guy with the rope wrapped around his body.
Keep the pics coming.
Roeland
#135 Posted : 30 January 2021 17:34:49
No Nelson supplied - I have to make one from train set figurine.
Roeland
#136 Posted : 30 January 2021 18:22:04
first undercoat
Roeland
#137 Posted : 31 January 2021 10:58:01
Nelson if finished.
Roeland
#138 Posted : 31 January 2021 15:45:52
Starting with the cut out.
Roeland
#139 Posted : 01 February 2021 14:27:21
Roeland wrote:
first undercoat
There will be less work to refine captain Hardy after his first coat.
Hardy is now finished - in my opinion an improvement on Nelson.
Roeland
#140 Posted : 04 February 2021 15:38:37
The guns for the cut out are now in progress. I painted the royal cipher on the barrels and had to enlarge the circumference of the middle deck guns as they did not match the dummy guns - this was done with heat shrinking tube. I also had to lower all gun carriages to line up with the dummy guns. Unfortunately I did not do the later two with the previous guns made. The eye bolts are made of 0.2 mm stainless steel wire. I used cast iron paint for the barrels and gave the trucks a wood colour finish with a painted pin.
10 Pages «<56789>»
This page was generated in 0.367 seconds.
