6 Pages <12345>»
MV Port Adelaide Options
John Passmore
#41 Posted : 02 January 2021 06:25:44
Hi Everyone
Here is another update, which shows start of infilling with balsa to the stern frames. The balsa is of bits left over from my SotS build, waste not, want not...Laugh
JohnP
John Passmore attached the following image(s):
John Passmore
#42 Posted : 12 January 2021 02:37:25
Hi Everyone
I have infilled the Stern and now the Bow flares with left over balsa from Sots...I think this will be a good basis for later cladding ( method yet to be decided....BigGrin Cool
JohnP
#43 Posted : 12 January 2021 17:47:14
All looking very good John.
Like the idea of infilling with the balsa. That should give you a lovely base to work the planking/cladding over.
Hope it all continues well.
John Passmore
#44 Posted : 26 January 2021 14:59:15
Hi Tony
Thanks for looking in and the kind words....BigGrin Yes, I've decided to infill the whole lot as the keel was still a bit floppy...Crying Should have made it a bit bigger!...Blink
Some progress follows...Cool
JohnP
John Passmore
#45 Posted : 26 January 2021 15:02:59
Hi Everyone
Here's a little more progress - working on the rudder / rudder frame...Cool A lot trickier than I thought and took quite a lot of trial and error before I was happy with it...Cool A bit more touching up to be done though....BigGrin
JohnP
John Passmore
#46 Posted : 26 January 2021 15:12:00
More progress now...Cool
Did more infill to stern section...Cool
Have decided to infill the complete hull as it seems too fragile...Blink Each section will be filled by hollow box using 9.5mm balsa -instead of a solid infill - and just as firm as it turns out...BigGrin Cheaper too!...Laugh
JohnP
budgie
#47 Posted : 30 January 2021 19:56:47
BigGrin Hi John
Looks like she is coming along well
With regards to comment you made on shaping the stern on my build
I think I will remove the filler at the last frame
Then once the planking is complete fill the last frame in again and sand to shape blending in with the final thickness of rest of hull
I think that may be the easier option
Looking forward to your next update
John Passmore
#48 Posted : 31 January 2021 08:05:10
budgie wrote:
BigGrin Hi John
Hi Budgie
Thanks for looking in - I think you seem to have your little problem solved...good one...BigGrin
Here's my latest update
Infilling the midships section of the hull...will soon have to start sanding and fairing....Cool
3rd picture shows the flat bottom so I can now dispense with the dry dock...Laugh
JohnP
John Passmore
#49 Posted : 02 February 2021 08:02:03
Hi Everyone
We are in lockdown here due to covid - we've got one community based infection after 10 months free!...Crying
So I've managed to push along...BigGrin
* Glued the lids on the infills
* Sanded the hull
* Trial fitted the 3 hull sections
Some minor adjustments to be done....BigGrin BigGrin
JohnP
#50 Posted : 03 February 2021 09:46:17
Hi John,
Really takin shape now.BigGrin
John Passmore
#51 Posted : 22 February 2021 14:06:01
Garth wrote:
Hi John,
Thanks for looking in Garth...Cool
JohnP
John Passmore
#52 Posted : 22 February 2021 14:09:42
Hi Everyone
Working on the prop shaft tunnels to create a foundation for the infill...Cool
Infilling depressions in stern hull - looks a bit ruff dunnit?...Laugh But not to worry folks it will all come out alright in the end...Laugh LOL
JohnP
John Passmore
#53 Posted : 22 February 2021 14:43:42
Hi Everyone again
Just a little more progress - and a bit of a milestone...Cool
* Fitted the 3 hull sections together;
* and the 2 final infills done....BigGrin
Next time: Hull sanding...Crying
JohnP
John Passmore
#54 Posted : 28 March 2021 06:39:41
Hi everyone
Some progress for March...Cool
Fitting of the Maindeck (stern section)
* Planked using 5mm x 1mm lime wood. Caulking achieved with a 2B pencil at 2.5mm widths to maintain scale. Then clear water based varnished - 1 coat only...Cool
* Extreme after deck is/was steel plate painted Red Oxide. Found a good colour match with Admiralty Paint Red Ochre...Cool
JohnP
John Passmore
#55 Posted : 25 May 2021 13:00:30
Hi Everyone
Here's some progress for April and May 2021
*Fitted Main Deck forward. Small gap of 4mm between that and the Main Deck aft...Blushing Easily fixed with a plate underneath and a strip inserted to plug the gap, the will be covered by superstructure later on...Cool
*Fitted Forecastle Deck with planks overlaid
*Made Forecastle deck bulkhead
*Made Anchor Windlass and Anchor Chain Guides
JohnP
#56 Posted : 25 May 2021 21:07:45
Hi John,
You`ve made some very good progress there and it looks fine WTG.
Cool Cool Cool Cool Cool
John Passmore
#57 Posted : 22 June 2021 06:27:56
delboy271155 wrote:
Hi John,
Hi Derek
Thanks for looking in and the nice words of encouragement...BigGrin
Yeah, it's pretty hard and I keep having to backtrack 'cos things don't always work out right!....Blushing
JohnP
John Passmore
#58 Posted : 22 June 2021 06:36:27
Hi Everyone
Here's my progress for June 2021.
* Modified the old SotS build cradle - nice and simple, this one....BigGrin
* First guide plank install around entire hull at main deck line....Cool Hoping it works out....Blink
* Working on Bow Flare of hull, lots of problems but getting there...Cool Balsa is only 1mm thick and clamps were a bit fierce! will fix all with filler....LOL
JohnP
#59 Posted : 22 June 2021 08:34:44
Certainly making excellent progress John and looks like everything is going very well indeed, all credit to your skills... Drool Drool Drool .. Am sure the hull will look amazing when the planking is complete... Look forward to seeing your next update....Cool Cool
John Passmore
#60 Posted : 23 August 2021 13:47:21
Hi Alan
Thanks for looking in and the nice compliments...BigGrin
Yes it is certainly far more difficult than I imagined, with lots of re-work, rectification and repair going on...Blink
JohnP
6 Pages <12345>»
This page was generated in 0.560 seconds.
