 Very nice Sticky If you have any space left will you be stowing essential victuals Maybe too hot back aft for stowing food tho Looking forward to your next update Glad you are under the new competitors build as makes it easier too find part 1 and 2 of your build diary as your link did not work for me  Will pour myself a glass of wine and go on a journey thru your build
Joined: 29/03/2011 Posts: 1,053 Points: 3,165 Location: Glenvista JHB
Hi Phil, Simply at a loss for words.....FANTASTIC!!! kind regards, Garth "Measure twice, cut once!!!" Finished!!! HMS Victory, Current build: Black Pearl. On hold: Bismarck, Golden Hind, Flying Scotsman, Victory Cross Section, SOTS, Tiger 1. Wish list: USS Constitution.
The work on that switchboard just leaves me speechless Phil, just incredible work....  .. Can see I've got a lot to learn.....  Regards Alan
Good morning from 'The Dockyard'. Thank you for the kind comments, much appreciated. So i didn't upload a post last week, even though i had a made a little progress, as i awaited an order of paint and varnish to arrive! The attached photo shows a heater/motor blower, completed, painted and ready for fitting. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
The attached photo shows a length of pipework with a valve/handwheel assembly ready for painting. The pipework was made from 2.0mm diameter solder. I found solder to be the best medium for making pipes as it's easily bent to shape and takes paint well. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Pipework and valve/handwheel assembly painted and ready for fitting. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
The attached photo shows both the heater/motor blower and pipework/valve/handwheel assemblies fitted. They are both above the switchboard with the heater/motor blower behind the block tackle on the left hand side. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
The next job was to make the overhead supports for the switchboard; 3 in total. Fairly quick to make and the attached photo shows them temporarily stuck with double sided tape to a scrap piece of plastic while i painted them. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Supports fitted on top of the switchboard and anchored to the hull. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
The final piece of detail i made was an electrical locker. I used 1.0mm thick plastic sheet glued to another to make the thickness 2.0mm, cut and filed to shape and a piece of 0.5mm brass rod, bent and fitted to form a handle. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Painted, varnished and pin washed. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Electrical locker fitted to the bulkhead, beneath the port main motor switchboard. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
That concludes this update. Thanks for looking in and commenting, much appreciated! Have a good weekend whatever you're doing and happy modelling! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Just mind blowing work. This should definitely be put in a museum for all to appreciate. Mark Regards Markwarren (Mark) Admin
Looking as good as ever. Your attention to all that tiny detail is amazing. How long do you think now until you get to the end point consider it all complete? Tony Happy Modelling
Utter brilliance as always Phil. Amazing!!
Kev.Per Ardua Ad Astra
The painting is so true to life with that 'lived in damp and grubby' look and those tiny additions really make this model superb! Definitely agree with the 'museum' comments! Very well done. Robin First wooden ship: The Grimsby 12 Gun 'Frigate' by Constructo Second: Bounty DelPrado Part Works Third: HMS Victory DelPrado Part Works 1/100 scale Diorama of the Battle of the Brandywine from the American Revolutionary War Diorama of the Battle of New Falkland (unfinished sci-fi), Great War Centenary Diorama of the Messines Ridge Assault Index for the Victory diary is on page 1
Markwarren wrote:Just mind blowing work. This should definitely be put in a museum for all to appreciate. Mark You're very kind Mark, thank you! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
birdaj2 wrote:Looking as good as ever.
Tony Hi Tony, thank you for your comments, much appreciated. How long until full completion? I estimate Summer 2022. Regards, Phil. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Kev the Modeller wrote:Utter brilliance as always Phil. Amazing!!
Kev. Thank you so much Kev! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Guest (10)
