Steering column issues Options
davidyat
#1 Posted : 04 December 2020 20:00:26
Don't know if anyone else had this issue with the steering column. First, the pinion doesn't seat all the way on the steering column. Trying to fit the dashboard with this discrepancy doesn't allow the pinion to properly engage with the rack. I took a break from this as I was getting frustrated. Since the steering column is metal, I'll grind it down to seat properly tomorrow and see if that works. Also, since the steering column is metal, I can't get the FP01 screw to seat all the way for the steering wheel and the wheel is a bit loose. Tried to hold the column with a small pair of pliers and got to the point where I was afraid I would break the screw off and be in a world of hurt. Anyone else have these issues?
David
#2 Posted : 04 December 2020 23:22:53
Haven't reached this stage yet but I will look out for this possible problem.
semaj
#3 Posted : 05 December 2020 00:22:28
Mine all fitted just fine
Building:
Complete:
mortyjeff
#4 Posted : 05 December 2020 01:08:47
Rank: Beginner Level 3
On my Steering column, I used an emery board to remove the paint and smooth the casting on the 'D' shaped end, then took a small exacto knife and removed the paint from inside the pinion. it is a tight fit, I 'tapped' the pinion onto the shaft. the screw went in without any issue.
BigGrin
Andreas
#5 Posted : 05 December 2020 07:37:57
Groups: registriert
There is a simple solution to both problems. Models are usually not cut a thread in the screw mounts. The reason for this is that different screws are used. One fine thread and other screws with self-tapping threads. With fine threads, I always cut threads in the screw mounts. This prevents the screw from tearing off without pretreatment. I always place a drop of Loctite thread locker in place before tightening the screws. When it comes to steering, metal works on metal.
Without proper lubrication, it will always bump up until the paint or coating is removed. There is a simple solution here, use model construction grease. There is Teflon grease for model making, which is also used in diffs and gears. Works flawlessly. Later on, the steering is heavily weighted, and preventive measures are helpful to prevent problems there.
Forum Support Team
davidyat
#6 Posted : 05 December 2020 14:49:39
Thanks for all the replies. I am also a model machinist. I make model steam engines that run on compressed air. I do have taps and dies that go down to 0-80 if I need them. I'll try that in the future if I run into problems.
David
" alt=""/>" alt=""/>
Eagle
#7 Posted : 22 December 2020 13:35:12
Red Medal: Red Medal
I simply removed the paint from the shaft gear and rack teeth with a wire brush attachment in a Dremel; it works smoothly without any lubrication at all.
JOHN-GT40
#8 Posted : 12 February 2021 21:24:00
clear and scrape off all black paint at steering column rack gear and give steering rack teeth a generous helping of silverhook clear silicone grease
This page was generated in 0.107 seconds.
