Joined: 25/03/2010 Posts: 472 Points: 1,357 Location: Hyde
Hi again It's been long time since I posted here last time but we are all busy :) I've received my copper tiles and I'm very excited after reading first part of copper tiling instructions posted today. I hope to get my hands on as quickly as possible. In the meantime I've created sample part of the hull just to check colours and copper sheating ;) On the first image you will se hull painted with copper paint and on second tiled with copper. I'm going to paint it with copper paint before tiling so even if tiling isn't 100% acurate, only thing you will see trough gaps in tiling is copper paint :) Have a look 1. Copper paint  2. Tiling on top of the copper paint
Good idea Tom MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Good to see you posting again. I too am going to tile over a painted hull, I spent a lot of time getting the hull smooth enough to paint, even after all the work that I put in, it would still need further work to make it acceptable. I found the copper paint very difficult to use, but as the paint is going to be tiled on I left it at a stage where the hull is smooth enough to accept tiles. Have you come to a decision on what adhesive to use, I don't want to start with super glue until I am happy with a system of applying the tiles. There are lots of tutorials around concerning tiling but I will stick with the one on this site. Good luck Steve..
Hi mate I got my hull ready for copper paint. Just need to mark warwe line and mask it. For the sample I made here I've used aliphatic glue (as for normal woodwork) and it worked quite well. It doesn't set too quick so you have plenty of time to position tile properly. I'm not sure if this will be my choice for model itself though. I need to do some research. Cheers
Hiya again Not been here for ages, sone fantastic builds apeared here. I managed to get some work done though. Not much, just painting. I painted lower hull in copper but tiles will go over the pain later on.   As you can see on the second picture the cutout is bit diferent than magazine one but that's my version and I'll stick to it :) Still need to get some gold painting done on the entry canopies but later on. One little tip while you painting the model. First I painted whole thing yellow orche, then positioned masking tape. Right now is very important step. Before you paint black just go over with the yellow on the edges where tape meets hull. Not doing it might result in black paint transfer under the tape and tuining your work. Painting it yellow before seals all gaps and then when you peal your tape off after all it looks just perfect. I hope I made it clear enough Thanks
Shes looking great
What a cracking build Tom...absolutely brill!!  Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
superb build Tom
Fabulous Job Tom MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Looking good Tom!! I have just started tiling, very very difficult and with the copper base coat makes it hard to see if the tiles are butted squarely. Which in one sense does the job the paint is there for, to hide any discrepancies, but if the base coat was a contrast ie. black,white then the butting process would be easier to see when placing the tiles. But getting back to your build, very impressive, I look forward to seeing your tiling. Steve..
Joined: 22/03/2010 Posts: 369 Points: 1,150 Location: Broadstairs
Great work Tom. Looks really good, well done. TIS
Joined: 07/01/2011 Posts: 399 Points: 1,212 Location: Penhill Estate, Western Cape, ZA
superb Tom! Your's is a dairy that I always follow as a reference standard.
Thanks shipmates for kind words. It is still great amount of work to do but I'm really looking forward to it Right now the big job ahead is copper tiling I need to get upside-down stand prepared and off we go Thanks
Looks great Tom, you should be proud.. Chris..On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Hello Been busy doing other bits and bats (on Victory of course) bot I'd like to announce that yesterday I started with copper tiles. Quite plesent but slow proces. I've tried few glues but ended up with Evo Stick Serious Glue from B&Q. Works really well, don't set too quick and with special cleaner you can remove all excess quite quickly. I'll try to get some images soon here. Stay tuned
Joined: 25/08/2010 Posts: 170 Points: 537 Location: Germany
Looks superb Tom, I wish I would be that far. Cheers, Timm My build diary hereCurrent Build:HMS Victory
Hi Tom, Great work so clean and precise,that last picture looks so cool thank you for posting you build. regards tf64. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Thanks guys. It's nice when somebody likes your work. Happy modelling.
HI Tom, Good clean and tidy model. Like your paint work. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Joined: 29/03/2010 Posts: 190 Points: 512 Location: Lytham UK
Hi Tom.. The victory is looking great, very well done. Best regards, Ian Ian Builds in progress: E-type, HMS Victory, HMS Endeavour, HMS Soverein of the Seas Wish list: Bentley Blower http://forum.model-space...spx?g=posts&m=30439
http://mxpublishing.co.uk/engine/shop/product/9781780920184/Hunt+for+the+Blower+Bentley
Guest (5)
