52 Pages «<1112131415>»
#241 Posted : 13 November 2020 16:40:04
That concludes this update.
Thanks for looking in, have a great weekend and happy modelling!BigGrin
#242 Posted : 19 November 2020 23:14:38
More progress this week adding details to the port main motor switchboard.
The attached photo shows the current stage of the switchboard. A little more work next week should see this done. I'll be adding handwheels after it's painted and these locate on all of the raised rods you can see. The smaller rods represent push buttons.
#243 Posted : 19 November 2020 23:15:40
Looking from another angle.
#244 Posted : 19 November 2020 23:19:45
I also spent a bit of time making 10 x voltmeter/ammeter dials. I drilled a 2.0mm hole length ways through a 3.0mm diameter styrene rod. Sliced this into small sections and then filed a 2.0mm diameter rod to a half moon shape, sliced this into small sections and fitted these into the holes to give the dial profile.
I also spent a bit of time preparing a photo to make into decals which i will fix behind clear sheet to give that depth and detail when placed behind the dial face.
The attached photo shows the half moon shapes fitted.
#245 Posted : 19 November 2020 23:23:48
goddo
#246 Posted : 19 November 2020 23:55:42
Phil,
The level of detail that you are putting into this build make it an absolute masterpiece.
Well done.
#247 Posted : 20 November 2020 00:44:36
I'm just bewildered by your skill level when it comes to scratch building the detail. So pleased you've done a very detailed diary on this build, there is so much information for members to tap into so thanks for sharing Phil...Love Love Love .. Eagerly looking forward to the next update....Cool Cool Cool Cool
#248 Posted : 20 November 2020 12:23:22
Really outstanding detail PhilDrool Drool
Regards PhilCool
#249 Posted : 21 November 2020 10:19:19
Somebody else who has a mallet to put their eyes straight after working.LOL LOL Excellent work Phil.Drool Drool
What I’d like to know is how many did the carpet monster get.LOL
#250 Posted : 21 November 2020 15:05:24
goddo wrote:
Phil,
Well done.
Thank you very much Chris!BigGrin
#251 Posted : 21 November 2020 15:08:13
Thank you Alan, much appreciated! I hope members can use some techniques i've featured in this build diary on their models.
#252 Posted : 21 November 2020 15:08:48
Regards PhilCool
Thank you very much Phil!BigGrin
#253 Posted : 21 November 2020 15:10:49
LOL Mark! I heard a few bits make that 'pinging' sound as they hit the kitchen floor, never to be seen again!BigGrin
#254 Posted : 26 November 2020 23:02:47
More progress made on the port main motor switchboard. First job this week was to finish off the voltmeter and ammeter dials.
The attached photo shows clear plastic sheet glued to the back of the dial faces. The clear plastic sheet came from the packaging off a cake box.LOL I also printed out the instrument dials onto water slide decal paper.
#255 Posted : 26 November 2020 23:04:32
I then fixed the decals onto 0.5mm thick plastic sheet and glued the dial faces on top of them. At some point over the weekend i will separate them all and file the edges smooth and round before painting.
#256 Posted : 26 November 2020 23:07:17
I then turned my attention back to the switchboard and drilled out 0.5mm diameter holes. Once done i could then insert a small length of brass rod to represent the catches for the individual panels.
#257 Posted : 26 November 2020 23:09:59
The attached photo shows the switchboard completed. I still have a bracket and a hand rail to make, but the rest is done!BigGrin
The voltmeter and ammeter dials will be added, along with the hand wheels, once it has been painted and several dozen brass plates added!
#258 Posted : 26 November 2020 23:10:41
From another angle.
#259 Posted : 26 November 2020 23:11:51
#260 Posted : 27 November 2020 07:26:10
As i`ve said many times - this is incredible!
Where do you get all the information from, how all this details have to look like?
This page was generated in 0.418 seconds.
