This took longer than i thought with a few mistakes having to be remedied. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
I also had to figure out a way of temporarily positioning it, so i could check the height, length and width and ponder how to support it once fitted. So, by fixing a piece of double-sided tape to the inside, i could stick the end of a pen to it and then i could move the box section into place, take a few measurements and remove it again. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
That concludes this weeks update, more to follow next week. Thanks for looking in, have a great weekend and happy modelling! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Good evening from 'The Dockyard'. Been a case of two steps back, one forward this week. The attached photo shows the end of the switchboard shell painted black on the inside as this will be ever so slightly visible when fitted. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
I then made an additional unit that fits underneath the switchboard. The inside of this was also painted black. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Mesh was fitted to both the switchboard and additional unit and both were then fixed together. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
When i came to test fit the switchboard with the additional unit attached, it became clear that the couplers i made a couple of weeks ago were slightly too large. So, out comes the switchboard followed by the removal of the couplers. I trimmed and filed the couplers before repainting and refitting. The attached photo shows the resized couplers fitted and the switchboard in it's correct location; horizontal, perpendicular and following the centre line of the u-boat and not the taper of the hull. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
That concludes this update. Thanks for looking in, have a great weekend and happy modelling! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Hi Phil, I managed to spend a good bit of time today finally catching up with your build diary. The more I looked the more gobsmacked I become....  ... Its great to see the level of detail is as high as its always been and its obvious you have an unending amount of patience. Truly outstanding work in every way... Very well done..... Regards Alan
Phil Good to see you were able to resolve the issue without to many problems. I am amazed at just how much fine detail you are able to pack into this model. I could do with your eyesight and steady hand that is for sure. Hope the res5 continues well for you. Tony Happy Modelling
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 6,866 Points: 20,915 Location: Northamptonshire, England
Another great update, and just when I thought you were nearly finished in there. Mark Regards Markwarren (Mark) Admin
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,060 Points: 15,326 Location: ipswich
Joined: 29/03/2011 Posts: 1,053 Points: 3,165 Location: Glenvista JHB
Hi Phil, Another awesome update Kind regards, Garth "Measure twice, cut once!!!" Finished!!! HMS Victory, Current build: Black Pearl. On hold: Bismarck, Golden Hind, Flying Scotsman, Victory Cross Section, SOTS, Tiger 1. Wish list: USS Constitution.
Good afternoon from 'The Dockyard'. Thanks for all of the comments guys, much appreciated. So this week i have been doing more work on the port main motor switchboard and made a start on the front fascia. I cut a piece of 0.5mm thick acetal sheet to size and added guides to what will be the inside. See attached photo. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
This photo shows the front fascia lined up against the switchboard body. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
The guides ensure i can remove the front fascia to work on it independently and refit or remove it as necessary, knowing that it will align correctly every time. The attached photo shows edging strips added. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Lots of measuring and marking out followed to determine the position of the control handles. Once marked, i drilled through each mark with differing sizes of drill until the final holes were 2.0mm diameter. 2.0mm rod was then inserted, glued and trimmed to length. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
The next job was to make all of the individual panels for the front fascia. Made from 0.25mm thick acetal sheet, cut to size, the attached photo shows the top panels fitted and the lower panels prepared. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
The lower panels were then cut horizontally, ending up with 12 panels. All of these were then fitted individually. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Looking from another angle. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Guest (5)
