13 Pages «<678910>»
Micks 1/200 battleship bismarck Options
#141 Posted : 18 October 2020 11:01:53
Hi thanks to all who looked in and left comments much appreciated.
Issue 79
Just another hull plate fix as before least got to second black and white stripe cheers mick. BigGrin
#142 Posted : 18 October 2020 11:16:09
Issue 80
Here we start on the aircraft hangers. First of all the instructions have the parts in letters,yet the parts are numbered.just take a as 1,b as 2 etc etc, and you be fine, first of all add all the plastic parts vents,doors and overhanging boat supports to each hanger, there not identical so pay attention, then it's onto the etch boat cradles on roof,3 tiny triangle etch bits on end each one, don't glue cradles on wrong way round, then it's a etch brace on the 3overhanging cradles, least there no etch bending on this issue.cheers mick.BigGrin
#143 Posted : 18 October 2020 11:29:50
Issue 81
Here we get another hull plate, this one not used at the moment as it's a removable plate to show bit of internal detail, the turbine and anti torpedo ribbing, which is built in a later issue, here we just fit the etch catwalks, first of all bend all the tabs at 90 degrees then glue down the center of the roof there both identical so easy to fit,then there are 2 smaller catwalks these are different so be careful gluing them on, just one note on these the instructions have got port and starboard mixed up, but follow the pictures not the text, and you be fine,unfortunately I forgot to take photos of these at this stage but you will see them next stage. Cheers mick BigGrin
#144 Posted : 18 October 2020 11:49:46
Issue 82
First of all we glue in 5 vents around the second main gun barbette, then make up 4 breakwater hinges, I find it easier to fit the metal hinges to the plastic bases for them why still on the sprue, then it's glue a ladder to the deck, then glue in the 2 breakwaters and the 4 hinges 2 each side.then it's back to fiddly etch on the aircraft hangers, first of all bend up and fit the handrails then there's a ladder going over the pitch of the roof this needs bending to.then there are 4 more small catwalks to bend and fit in place,and finally 2 ladders to fit on the sides, then just glue the hangers to the deck one each side of the funnel. Then one final pic of it all put together, that's it till next time cheers mick. BigGrin
#145 Posted : 20 October 2020 22:29:39
Looking great Mick. Doing a wonderful job on her. I'm in two minds to buy the Trumpy Bismark to add to my todo list. There is meant to be a 1/200 Tirpitz coming soon too.
#146 Posted : 21 October 2020 15:49:47
Coming on very nicely Mick.Love Drool
tubab
#147 Posted : 25 October 2020 13:15:09
Rank: Amateur Level 1
Hi to all the builders of this, I am wondering if the anchor chains will be adjusted at some point, the connection to the anchor was changed and could be hauled up to deck level but at present the test only lifts and drops it a few inches.
#148 Posted : 25 October 2020 17:54:10
Hi i would imagine the anchors will set themselves up when all electrics complete ,the secondary guns will also need setting as there anywhere at moment ,cheers mick.BigGrin
#149 Posted : 26 October 2020 17:05:32
Nice update MickBigGrin
Regards PhilCool
#150 Posted : 26 October 2020 23:39:30
Hi Mick, BigGrin
This is now taking on some serious size and looking good.
Cool Cool Cool
How many issues are scheduled for this one, as at issue 82 it looks like your just little over half way?
#151 Posted : 27 October 2020 11:42:14
Hi thanks to all who looked in and left comments much appreciated, hi del this 140 issues ,so 58 left till complete cheers mick.BigGrin
#152 Posted : 29 October 2020 18:31:52
Looking very good Mick!Love It's a bit of beast!Blink
#153 Posted : 29 October 2020 19:30:11
Mick
All looking very good.
I am “collecting” rather than building but at the point wondering best course of action. I am a month behind you in terms of editions but not sure if i really want to continue.
I see that agora models are going to sell the display case as a standalone item for this model meaning original hachette builders will be able to get it.
Hope yours continues well.
#154 Posted : 14 November 2020 17:03:48
Hi thanks to all who looked in and left comments, Chris think I'll be looking into the tirpitz when it comes out.meanwhile back to this one.
Issue 83
Just another hull plate fix as before,I'd imagine the holes are where the speakers will go to let the sound out cheers mick. BigGrin
#155 Posted : 14 November 2020 17:12:36
Issue 84
We get to fix the superstructure to the deck via 6 screws from underneath, you have to remove the turret turning motor to access one of them, then put it back the rest is sorting out the wires fixing the main circuit board box and plugging in the 22 plugs.this was just frustrating at times working underneath and not damaging all the superstructure. Just 2 pics as not going to bore you with every wire that's put in. Cheers mick. BigGrin
#156 Posted : 14 November 2020 17:20:35
Issue 85
First of all fit another hull plate, then it's various bits of etch to bend and fit around the second main gun barbette, this includes metal grills ladders and walkways, easy enough just fiddly, sorry for the glare on pics but was working under a bright light to see what I was doing.cheers mick.BigGrin
#157 Posted : 14 November 2020 17:32:56
Issue 86
First of all we make up 10 small vents by gluing on the bits of etch to the vents, then glue them in around the second 15cm gun 5 each side, these were a pain to get in working behind the gun and with the boat cradle above them,then we make up the 2 heavy anti-aircraft guns these just sit in the holes on the deck above and behind the 15cm guns, then we put in the preshaped handrails 2 each side again access is difficult behind everything, then just 5 etch ladders to glue in.thats it till next time cheers mick. BigGrin
#158 Posted : 14 November 2020 17:56:19
She's looking really good Mick.. Hoping there will be a video of some kind showing all of these electronics in operation. Lovely work throughout, very well done....Drool Drool
#159 Posted : 13 December 2020 13:14:40
Issue 87
First of all we make up 2 more anti aircraft guns, then make up the flying bridge platforms one each side, then bend the handrail for these and glue them on the flying bridge can be out or tucked in as it swivels. Then 2 more bits of handrail to bend and fit , one each side again, then 2 preshaped bits of handrail added on the next deck below, then 2 straight small bits of handrail fitted just behind the rangefinders. Cheers mick BigGrin
#160 Posted : 13 December 2020 13:22:56
Issue 88
First of all fit another hull plate, then just few deck details to add sounding line platform, that's the bit in front of the breakwater, few bollards and fairleads. Cheers mick BigGrin
13 Pages «<678910>»
This page was generated in 0.357 seconds.
