 Rank: Newbie Groups: New Members, Unapproved Joined: 25/10/2020 Posts: 1 Points: 3 Location: Seattle, Wa
Dose any one know what is the positive and what is the negative for the wiring of the droid motor?
When I received the motor the wires were broken off and I am not sure what one I should solder to what side of the motor terminals. One of the wires has a white dashed line along it. I am not sure what side of the motor that connects to. Any help would be great and Thank you all!
 Rank: Semi-Pro Level 1  Groups: Registered, Forum Support Team Germany, Official Builds, Tech Support, Moderator, registriert, Administrators Joined: 27/09/2016 Posts: 73 Points: 209 Location: Berlin
Hello Jason, on the side with the arrow comes the wire with the white marking  Greetings Stefan Alle Berichte sowie alle Fotos unterliegen dem Urheberrecht. Verwendung außerhalb dieses Forums bedürfen schriftlicher Genehmigung/Zustimmung meinerseits. © StefanForum Support Teamhttp://www.model-space.com/de/ https://m.youtube.com/watch?v=qIC4f1LE86w
MfG Stefan
