Joined: 08/02/2016 Posts: 159 Points: 520 Location: Česká Republika
I am starting the construction of the Yamaha YZR M1 model in 1/4 scale from the DeAgostini company. I was very much looking forward to this construction and thanks to my health rest and vacation, I decided to start building. As usual, I will finish and modify a lot of parts on the model, but you know me 😀😂🤣. I have a finished model in my head in the exposed state, so I will proceed in the construction as well. I wish you a nice peek, I believe that you will follow the construction and not reject it. I started by building a front fork. It is already sprayed in the kit, but it is very far from reality. In the photo two, three and four there is an original part on the left, a spray-painted part with a decal according to the original on the right. I sanded the fork, sprayed it with a black filler and sprayed it with Titanium gold X-31 acrylic paint from Tamiya. After perfect drying, for about 24 hours I applied three layers of Clear orange X-26 acrylic paint on the fork and painted the whole with semi-matt varnish. Personally, I am satisfied and I think that the result has shifted to reality as I imagined. The next step was to spray the two fork bars and assemble the right and left legs. That's all for today, I'll see you again soon.
 Nice start Ruda, with improvements over the original! (  Ummm....wonder if i can retro-steal your ideas  ) Great to see another Rossi Bike started on the Forum Regards Gray
CaptnBirdseye wrote: Nice start Ruda, with improvements over the original! (  Ummm....wonder if i can retro-steal your ideas  ) Great to see another Rossi Bike started on the Forum Regards Gray I am glad that I can present the building here on the forum. The use of the same method is a matter of course. We are modelers and we have to help each other.
Joined: 11/03/2010 Posts: 234 Points: 734 Location: Whelpley Hill, Chesham
Very nice detailing. Alec Built: Bluenose, Arab Dhow, HMS Bounty, Hummer H1, D51, Spitfire,E type Jaguar. In Progress: HMS Victory, , Yamaha YZR-M1
Adapt, improvise, overcome.
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,195 Points: 15,734 Location: ipswich
Great work. It's looking really impressive. Lovely to see another one of these being built. Keep it coming.
Very nice work and great start. Mark Regards Markwarren (Mark) Admin
Yesterday's and today's work on the exhaust was quite successful. The parts of the exhaust are made of metal in a kit, sprayed with silver paint, all of which are studded with dividing planes and all the parts are screwed together and the screw heads are in visible places. I screwed all the parts together, I screwed the holes with screws and all the joints with epoxy and after five hours of drying they sanded everything. I sprayed the whole with a black surfacer from Gunz and let the whole dry thoroughly overnight. In the morning, I sprayed everything with Alclad II paint of various shades and then shaded everything lightly blue. I added lambdasondes and the exhaust is ready for installation.
Excellent update, really look good. Mark Regards Markwarren (Mark) Admin
Very, very impressive. Loving the updates.
Excellent work. You’ve definitely an eye for detail. Mark Regards Markwarren (Mark) Admin
We have another lighter process in the construction of the Yamaha YZR M1. There is nothing in the seat fairing in the kit. The manufacturer does not count on my idea of the removed part of the saddle, so I have to finish the electronics that are in this space next to the original. From Thursday, I tentatively cut a part that I will have to make from plastic plates and tentatively tested it in the saddle parts. After a few tests, I found out the required shape, length and height of the part. Then I took a 0.8 mm thick plastic plate, Evergreen plastic profiles and started cutting, drilling and gluing. After about two hours, I got to the part that will carry the electronics, battery and camera parts. I assembled and glued the battery block from the plastic profiles, which is so far only roughly blinded and sanded. I glued the battery holder and placed it on the central electronics board. This work on the back of the Yamaha will be lengthy and still take a lot of time, plastic plates and profiles, I still have a lot of electronics and cabling ahead of me. A very similar thing is still waiting for me in the front part, but there will be even more and much more complicated parts.
Guest (6)
