4 Pages «<234
Ronalds Stern Planking Problem Options
ronald305
#61 Posted : 27 September 2020 01:33:01
thanks Alan
you cleared up a lot of confusion for me just one last question what do you mean when tease the bend in to place so I can try that as well thank you
Ronald
#62 Posted : 27 September 2020 08:14:28
It means ease the bend into place, don't force it by applying too much force...
ronald305
#63 Posted : 27 September 2020 13:25:15
of course why didn't I see that ok thanks
Ronald
ronald305
#64 Posted : 27 September 2020 18:43:57
HI Alan
sorry for all the questions I never seem to run out of them LOL any way the 2 planks you want me to temporary pin on top of the ribs did you want them bent to
fit the ribs or just 2 regular strips of planks pin the top
Ronald
#65 Posted : 27 September 2020 19:42:02
ronald305 wrote:
HI Alan
Ronald
Just pin them to the ribs (Except 30), no bending necessary...
ronald305
#66 Posted : 27 September 2020 20:15:01
ok thank Alan
I'll start working on the first stern planks tomorrow (no gluing, and only
bending around the stern and no twisting yet
Ronald
ronald305
#67 Posted : 28 September 2020 19:59:05
Hi Alan
here are a few photos of the bent stern planks and the top planks in place
as far as the stern planks I tried to bend a them like the ones in the
instructions they are not coming out good with the crimpers that is even when I
tried to be gentle the turns are still showing splinters, so would like your
permission to try bend theme using my iron as I did in the past soaking them as
well, try two new ones, I almost forgot to mention since the stern planks are
temporary and not glued I did not trim the ends toward the bow as you can see
in the pictures
Ronald
ronald305 attached the following image(s):
ronald305
#68 Posted : 29 September 2020 01:59:11
HI Alan
I had these two photos taken of the right and left side of the stern with the
bent planks in place as you can see the left side has a bad turn to it I tried to fix it by soaking it and using my iron but the stress marks and splitting is from using the crimpers first, that will have to be replaced the right side is not bad that I can see. I did not do any twisting to either one they just have the bend in them PS this post is a part of the last post I sent this afternoon, your thoughts, advise & next instructions
Ronald
ronald305
#69 Posted : 29 September 2020 18:31:20
two new and better photos of the stern planks bent right and left ( replaced the left plank with a newer one
Ronald
#70 Posted : 29 September 2020 22:33:39
Its getting there Ronald but you need to bend the plank more to get round the curve. Use the iron first then the crimper, not the crimper first. It is tricky and you just have to keep trying. Once you have the plank looking like step 4 of the instructions then we can move forward a little more. There is nothing more I can tell you on how to achieve this I'm afraid.
ronald305
#71 Posted : 29 September 2020 23:01:37
ok bend them a little more like part 4 in the instructions, use the iron first and then the crimpers thanks Alan
Ronald
admin
#72 Posted : 30 September 2020 06:00:58
I am going to lock this thread. There is an incredible amount of rock solid info that Alan has given. At this point, it is incumbent on the builder to think it through, and refer to the pertinent pictures and descriptions.
Ronald, you’ll be getting another pack with the strip wood, so you have one or two extras to cautiously trial with. I think you’ll find it super easy! Try my steam bending, for comparison.
Thanks to you both for the dialog that was really informative!
4 Pages «<234
This page was generated in 0.217 seconds.
