11 Pages «<45678>»
1:24 Smokin Dragster ( Another Stage Closer) Options
#101 Posted : 20 September 2020 20:29:18
tigerace wrote:
Looks Excellent DerekDrool Drool love the colour mateLove Love
Regards PhilCool
Hi Phil
Thanks for looking in.Cool Cool
I had to find a vibrant red, as the main side decals have a base colour that is red/brown. So if the red had been dull it would have merged with the decal. All will be revealed more when I add the decals.
I used a "Halfords" rattle can called Hyundai Electric Red if anyone needs a bright red for a model.
#102 Posted : 21 September 2020 22:21:51
Hi All,BigGrin
Whilst waiting for the body paint to dry on the Pro-fuel dragster and having done my bit cleaning up the local canal, I`ve started on the second phase of surgery on the driver.
Having straightened out the drivers body it means that his arms are totally wrong.
As its the Pro-fuel dragster that is getting ready on the start line, the driver needs one hand on the steering and one raised in acknowledgement of his crew. So I needed to straighten one arm almost totally and then I only need to adjust the position/angle of the other arm.
In the pic below I have cut the left arm almost right through at the elbow, then shaped a piece of scrap sprue to a "V" shape and glued it into the opened elbow joint. When fully set will cut off the excess (red line) and fill and shape ready for fixing to the body and painting.
Hope to be setting up the two smoke generator test tomorrow.Blink Blink
#103 Posted : 22 September 2020 20:08:04
Looks great Derek, that's a nice shade of red, really sets off the whole model and seems to have laid down nicely with a great finish considering it's from a spray can. Like your method of filling the gap in the drivers' partially severed arm as well - bet that hurt! Blink Huh
Well done. Cool ThumpUp
#104 Posted : 22 September 2020 23:30:03
Love the red you have used on the body Derek.
That looks like a very long model as well, its going to look very nice when its all together.
#105 Posted : 23 September 2020 23:12:44
Thanks to all who have looked in and to Kev and Tony for your comments.
Cool Cool Cool
I`ve come to a small impasse due to delivery issues. I wanted to get the two smoke generators running at the same time, but the power distribution board has not arrived as yet and I won`t play around with bits of wire all over the place even when using low voltage as some of the components don`t come cheap and this dio is mounting up on the cost front.
I don`t mind the overall cost, but it could get silly if I start blowing power supply units, power convertors, smoke generators etc etc. Or worse still if something goes wrong and I damage one of the kits.
So will give the next update as soon as the required parts arrive. When Covid restrictions and postal services running somewhere near normal allow. Crying Crying
#106 Posted : 24 September 2020 08:34:16
Very nice work Derek, love the colour.Love Love You don’t realise how long these things are.Cool
#107 Posted : 25 September 2020 10:35:38
Hi Mark BigGrin
I am very happy with the paint job and the colour. As for the size, this one is 1:25 scale and measures in at 40 cms in length. so if my calculations are correct the real thing comes in at 10 metres.Blink
#108 Posted : 25 September 2020 10:59:31
Hi All, BigGrin
UPDATE
Good news is that the Postman arrived with my bits and pieces for this and paints for another build in the planning.
As postie was nice and early I`ve put together the circuitry for this build in temporary form till I start building the dio base.
In the picture below I have just placed the switches where they will be in the final build.
Switch 1 on and switch 2 off gives the smoke generators time to start up.
then
When the smoke generators kick in.
Switch 1 on and switch 2 on runs the motor for the wheels with the smoke working.
I am toying with the idea of putting a variable timer in place of switch 2. This should then in effect make it work off the one switch that will power the smoke generators with the timer starting the motor after a pre determined time delay, ie the time it takes the smoke generators to start working.
If this bit happens will be determined by cost. Crying
That`s it for this update, except that I`d like to extend my thanks to Mark Warren for his tips and assistance with this circuitry both on and off the forum. BigGrin Cool BigGrin
#109 Posted : 25 September 2020 14:51:01
Hi Again, Blink
In preparation for the two smoking wheels test I`ve made a test jig (adapted from the initial one). This also gives me a better idea of how to get the workings of the dio base in the best shape.
The smoke generators need to be set beneath the wheels in the base, but also need to be accessible to replenish the smoke oil.
The following will obviously need adapting for the final base of the dio.Blink
Pic 1: shows one smoke generator placed into a base.
Pic 2: shows both smoke generators in the base, but slid out for putting in the smoke oil.
Pic 3: Shows the base slid back into place to get the smoke under the wheels.
I am now getting more confident that this is now a viable working dio. (Phew)
Test video coming soon. Grandchildren`s needs permitting over the weekend.LOL
#110 Posted : 25 September 2020 15:05:40
Woohoo, now that is definitely coming together now.Love Love Drool Great idea for the timer delay to give the smoke generated a chance to heat up.Cool Cool
I told you electronics was simple.Flapper LOL
Looking forward now to seeing this all work.Love Love Love
#111 Posted : 25 September 2020 15:30:21
looking great. its such a novel idea.Cant wait to see the wheels turning and the smoke.
#112 Posted : 25 September 2020 17:43:13
Thanks to Mark/Carl for your comments.
Cool Cool Cool
Should have the next video up before the weekend is out, as long as my Granddaughter doesn`t turn her karate skills on me. (She`s 14 but hits damn hard and kicks better than a mule)LOL LOL LOL
#113 Posted : 25 September 2020 19:16:27
Hi looks to be progressing very well ,will look great when done cheers mick. BigGrin
#114 Posted : 25 September 2020 21:20:07
Thanks Mick, for taking the time to look in and comment.
Cool Cool Cool
#115 Posted : 26 September 2020 12:21:15
This is going to be fantastic DerekDrool Drool Great updateBigGrin ,i`m glad you know what you`re doingFlapper LOL LOL
Regards PhilCool
#116 Posted : 26 September 2020 13:13:48
Regards PhilCool
Thanks for looking in Phil.Cool
I`m just going out to collect my Granddaughter and will put up the working prototype video on my return.
Don`t tell everyone though. LOL LOL LOL
#117 Posted : 26 September 2020 14:53:55
Hi All, BigGrin
Well its now a proven build with respect to the "Smokin Wheels"
A pic below shows the prototype wired up roughly for now.Blink
The bit that has been awaited by those following is available in the video link below:
I have upped the voltage supply to the smoke generators from 8v to 12v which generates more smoke. Confused May have to turn it down a bit, or the smoke alarms will be going off. LOL Flapper LOL
https://youtu.be/8mTxgcNlmeE
Now I can start designing the base of the dio.ThumpUp ThumpUp
#118 Posted : 26 September 2020 17:01:50
Now that looks very impressive work. Love Love Love it.Drool Drool
kpnuts
#119 Posted : 26 September 2020 19:17:22
Looking great mate.
#120 Posted : 26 September 2020 19:29:40
Thanks Mark/Ken for looking in and the comments.
Cool Cool Cool Cool Cool
11 Pages «<45678>»
This page was generated in 0.222 seconds.
