Help please Victory question Options
Roeland
#1 Posted : 18 September 2020 18:58:09
Hi
I have a question... next part of my build I have to install the main sail yard but the forward yard brace seems to be an interference with the sail? Is this normal?
Thank you
Roeland
#2 Posted : 18 September 2020 21:22:55
Hi Roeland, can you advise the build stage you are working on and post up a pic showing the interference problem you are experiencing, it would help us.....
Roeland
#3 Posted : 19 September 2020 08:35:56
It will be the start of issue 108. I'm not there yet but I attach a picture me holding the main yard in position. The yard will fit but the fore yard brace will touch the sail. In reality I would see this as very impractical?
Roeland attached the following image(s):
#4 Posted : 19 September 2020 12:40:52
Hi Roeland, am not seeing too much wrong here. For now, I think you should carry on with the build and lets look at it again when you have the main yard and sail fitted to the mast....
Roeland
#5 Posted : 19 September 2020 16:38:54
Hi Alan - thank you - I will be ready to start the main sail on Monday and will keep you in the loop.
Roeland
#6 Posted : 21 September 2020 14:31:01
I have another question relating to the stay sail sheet lines positions and fixing method. On the model they are fixed straight to eye bolts but I presume there would have been some blocks as well - refer to attached image.....?
#7 Posted : 22 September 2020 23:24:09
Although the instructions do not show the fitting of blocks there is no reason why you can't or shouldn't fit them, providing you've got spare blocks for the task. Down to personal preference here I think....
Roeland
#8 Posted : 28 September 2020 15:59:14
Hi Alan,
I fitted the main yard and you can see the 2 braces against the sail. Is this normal?
Thanks
Roeland
#9 Posted : 29 September 2020 22:37:39
Hi Roeland, can you confirm the build stage number where you fitted to 2 braces giving concern?
Roeland
#10 Posted : 30 September 2020 13:57:26
Hi alan,
That was issue 106.
Roeland
#11 Posted : 30 September 2020 16:06:10
Difficult for me to see for definite but looks as if you have terminated the braces at the wrong point. If it is line 'E' you're referring to (as per image below), can you confirm the braces are terminated on the cockpit rail?
Roeland
#12 Posted : 01 October 2020 14:44:26
Sorry - I made a mistake - it is line G in issue 105.
#13 Posted : 01 October 2020 15:27:48
Thanks for the clarification Roeland. As far as I can see the lifts and braces look just fine, not seeing anything wrong with them. In fact, I'd have to say I think you're doing a first class job with your build.... Very well done indeed....Drool Drool Drool
Roeland
#14 Posted : 01 October 2020 15:44:26
Thanks Alan,
Does this mean these lines have a bit of slack when the wind blows in the main sail or do the lines restrain the sail under wind load?
Roeland
This page was generated in 0.256 seconds.
