10 Pages 123>»
Roeland Options
Roeland
#1 Posted : 18 September 2020 17:59:11
Hi,
I spend so far about 3000 hours on my build and nearing the finishing line. I would like to share some pictures and receive feedback. Can somebody please advise how I attach pictures .....?
Many Thanks
Roeland
z8000783
#2 Posted : 18 September 2020 18:03:56
Groups: Unapproved
Yes, create a post and tick the 'attach files' box and then save the post.
It will then ask you to browse for the files you want to put up. You then upload them. Do this as many times as you need to.
Remember though, once they are up, seeing them can be problematic but this is not your fault.
The new forum we have been promised should cure the problems.
Roeland
#3 Posted : 18 September 2020 18:07:39
Got it - first pick of overall process. One of the later ones is this acupuncture exercise taming some ropes.
Roeland
#4 Posted : 18 September 2020 18:10:04
PS - you can see the date I joined - I started the model a bit before that time
z8000783
#5 Posted : 18 September 2020 18:12:36
Groups: Unapproved
If you resize your pictures, they will show in your post rather than members having to download each one in order to view.
I scale mine to a width of 660 px. That seems to work fine.
Roeland
#6 Posted : 18 September 2020 18:19:38
ok let me try with the first 2 posted
Roeland attached the following image(s):
#7 Posted : 18 September 2020 18:27:49
Hi Roeland, BigGrin
A very nice build indeed.Cool Cool Cool
If you need any more info on uploading/resizing pics, take a look at this link:
https://forum.model-spac....aspx?g=posts&t=244
Roeland
#8 Posted : 18 September 2020 18:33:40
Thank you -I try again with another one - you will notice I took some liberties based on my primitive research available on the network.
#9 Posted : 18 September 2020 18:34:20
For some reason second pic shows ok but first is only available to download???
Build Looking good though ThumpUp
Regards Gray
Roeland
#10 Posted : 18 September 2020 18:38:16
I made the resolution to large - try again....
Roeland
#11 Posted : 18 September 2020 18:47:31
sorry this one does not re-size without a degree in IT
#12 Posted : 18 September 2020 18:50:48
Hi Roeland, BigGrin
You can take a pic at any resolution. Obviously the higher the resolution the better the quality of the picture, but the available width for pics on the forum is approx 650.
So if you go into edit on your pics and use resize and choose pixels, change the width to 650 pixels they should then show. The last one was about 750 pixels.
Roeland
#13 Posted : 18 September 2020 18:55:03
ok thanks I try
Roeland
#14 Posted : 18 September 2020 19:14:13
Roeland wrote:
ok thanks I try
slightly altered bobstays
#15 Posted : 18 September 2020 19:31:53
Hi Roeland
Please check your inbox at the top of your page when you are logged in. I have sent you a PM (Private Message)
Roeland
#16 Posted : 18 September 2020 19:48:31
delboy271155 wrote:
Hi Roeland
done - next question will be the bunt lines....
Roeland
#17 Posted : 18 September 2020 19:57:46
foremast detail 2
#18 Posted : 18 September 2020 20:55:32
Looking very impressive Roeland, very well done....Drool Drool
Roeland
#19 Posted : 20 September 2020 16:16:20
Just installed the brail lines - I made the blocks smaller.
and a modified driver boom topping lift - not sure if this is correct? and the bottom with hook....
Roeland
#20 Posted : 22 September 2020 15:00:58
Another view on progess....
10 Pages 123>»
This page was generated in 0.294 seconds.
