52 Pages «<678910>»
#141 Posted : 18 September 2020 07:11:54
Thankyou for all the nice comments!BigGrin
So this week has seen me add more detail to the main motors.
The attached photo shows the manual cranking handles fitted. I'm not entirely sure, but i believe these were turned with a spanner while the inspection covers were opened, for maintenance.
They were made from 1.0mm OD, 0.8mm ID brass tube with a small length of 0.8mm diameter brass rod inserted into each section.
#142 Posted : 18 September 2020 07:14:14
Looking from another angle.
#143 Posted : 18 September 2020 07:22:11
The next stage was to start building some of the ancillary detail. The attached photo shows a starter, made from styrene rod and sheet.
#144 Posted : 18 September 2020 07:23:11
I haven't fitted it yet, but this photo shows where it will locate on the port main motor.
#145 Posted : 18 September 2020 07:26:00
I then turned my attention to a similar type of 'starter' for the starboard side. The black section is in fact part of an old biro!LOL It just so happened to have the right diameter!Flapper
#146 Posted : 18 September 2020 07:35:13
This photo shows some of the detail on this starter including wire type latches.
#147 Posted : 18 September 2020 07:36:42
The attached photo shows it in position, but not fitted, on the starboard main motor.
#148 Posted : 18 September 2020 07:38:09
#149 Posted : 18 September 2020 07:39:48
That concludes this update.
Thanks for looking in, have a great weekend and happy modelling!BigGrin
goddo
#150 Posted : 18 September 2020 08:05:33
Great work Phil.
Keep the updates coming.
#151 Posted : 22 September 2020 11:51:25
Hi Phil,
Great update as always.Drool
#152 Posted : 24 September 2020 08:18:47
Very nice work Phil.Love Love You must know your way around the engine of the real thing by now.Cool
#153 Posted : 25 September 2020 08:29:09
Thank you Mark! Yes, i'm thinking of writing a Haynes manual on u-boat air compressors!LOL Flapper Now that would be a very specialised subject on Mastermind! lol.
#154 Posted : 25 September 2020 08:31:07
More progress this week on the main motors.
The attached photo shows the 'starter?' connected to the starboard main motor.
#155 Posted : 25 September 2020 08:32:19
'Starter?' fitted to the port main motor.
#156 Posted : 25 September 2020 08:34:20
Now it's onto the final job of making the air coolers for both main motors.
The attached photo shows the scratch built electric motors that power the air cooler fans.
#157 Posted : 25 September 2020 08:34:52
This photo shows the fan housings being made.
#158 Posted : 25 September 2020 08:35:25
Air cooler casing being assembled.
#159 Posted : 25 September 2020 08:36:16
Air cooler casing work in progress.
#160 Posted : 25 September 2020 08:39:15
I then fitted mesh across the air cooler fan opening and finished off by wrapping a strip of 0.25mm thick styrene sheet to make the outer body.
The attached photo shows the air cooler fan housings and electric motors completed.
52 Pages «<678910>»
This page was generated in 0.446 seconds.
