56 Pages «<34567>»
willie
#81 Posted : 10 September 2011 19:41:20
to me screwing it down to a board through the keel is more holes to plug to stop water getting in if sailing , fixing to board buy other ways screwed clamps out side of keel etc is the way i am going
#82 Posted : 10 September 2011 19:50:06
Willie,We build the Hull under this false keel this part does not go near the water,when we have built all thr ribs we unscrew it off the board, and plank a hull underneathCool
willie
#83 Posted : 10 September 2011 20:00:48
i know but water will find a way i have built a double plank boat be fore planks over lapping the first plank joints with the second plank and water still found its way in all because a pinhole in the middle of a plank ended up in the middle of a joint found out by flooding the boat in side and looking for the weep and if this build is the same as the bismarck you plank from the top down take a look at the builds on you tube the russin one good and how he fixes his planks with rubber bands so they pull in and up tight to the next one
#84 Posted : 10 September 2011 20:20:50
Zeptrader wrote:
I have seen this also but think it just shows a few sample steps and not a build diary. More of a getting started page to show any newcomers what to expect, if they do a build diary or any updates past issue 4 I would be very surprised and offer a MASSIVE appologey .
dont get too excited by it:)
oh and MWG, looking good but as Mr T pointed out watch the clamps, get it screwed to a board mate, superb stuff, I'll be doing mine after the race on sunday and updating a blog;) again!!!
Have to agree with you Colin, its unlikely the build will be shown beyond issue 4
#85 Posted : 10 September 2011 20:23:51
Its a double planked build, if you properly water seal inside and out with a proprietory water sealing method, then all will be fine .
S2ksean
#86 Posted : 10 September 2011 21:13:42
Thanks for ya help so far lads I'm sure it won't be long before I'm bugging ya all again lol
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
#87 Posted : 10 September 2011 22:42:20
ISSUE 2
Just thought you would like to see the Hood in its Dry Dock:-
#88 Posted : 10 September 2011 22:44:13
You will see the tops of the ribs come off cleanly as they should:-
#89 Posted : 10 September 2011 22:46:35
And finally for this session WOW SHE IS GOING TO BE BIG!!!!!!Blink
Zeptrader
#90 Posted : 10 September 2011 23:20:50
nice one BigGrin
budgie
#91 Posted : 10 September 2011 23:25:19
BigGrin Hi following ure diary with interest
i screwed my Yamato down to a PINE base, but unfortunately i kept it in the shed thinking its going to go in or under the water (as top heavy)therefore keeping it in the shed should not be a problem
Over the winter period not realising that the birds had pinched half the roof so when it rained well u can guess where the leak would dribble onto
The wood got sodden and even the base ended up warped therefore the false hull was warped too
Cool Thinking about getting a tin can like ColinFlapper
Zeptrader
#92 Posted : 10 September 2011 23:34:13
I'll tell ya the 'tin can' has not leaked one drop, no spider webs, cleanest shed ive ever had, cold..yes, hot in the summer no.
gonna sort my build base soon enough.
#93 Posted : 11 September 2011 02:33:33
Thanks for your nice comment ColinCool
#94 Posted : 11 September 2011 10:14:16
Good Morning Everyone
#95 Posted : 11 September 2011 11:23:46
Can I just chip in that a pine build board is probably the worst material to use, pine is prone to warp amd movement.
A minimum 12mm melamine/conti or MDF board avoids this risk.
Also its not wise to store a wooden model of any description in an outdoore shed, the changes in interior atmospherices from day to day be it sun one day and rain the next, can do all sorts of nasty things to the wooden framework of as model.
#96 Posted : 11 September 2011 19:01:59
Thanks MR T, This board was the one I used for the Victory,its well cured, and I keep all my Models in the House, but as usual your advice is correct I appreciate your input.Cool
#97 Posted : 12 September 2011 23:59:52
Sorry to here of your shed problems BudgieHuh
S2ksean
#98 Posted : 13 September 2011 00:06:05
When's issue 3 out is it Wednesday. Il be hopefully doing mine Thursday then putting up the pictures if I can ever work out how ta do it on my iPhone
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
#99 Posted : 13 September 2011 00:18:29
Hi Sean, yes issue 3 is out on Wenesday, I am sure you will work it outwith your iphoneCool BigGrin
#100 Posted : 14 September 2011 11:31:15
ISSUE 3
Picked up the above this morning, contains 2 ribs for the stern and a piece of false keel.
Guest (5)
56 Pages «<34567>»
This page was generated in 0.272 seconds.
