16 Pages «<7891011>»
Malc's 1/12 Alfa Tipo 158 Options
#161 Posted : 01 September 2020 09:07:11
Thanks for all the nice comments Guys.
#162 Posted : 01 September 2020 09:10:19
The two side fuel tanks and the rear tank are connected by a system of pipes and this change-over valve. There's a lever to be attached that the driver would operate.
The pipes have to be formed from Alum' rod. That was a bit tricky..
#163 Posted : 01 September 2020 09:13:38
Views of the rear tank and suspension.
#164 Posted : 01 September 2020 09:39:29
Looks like your heading toward an excellent display piece in the end.
The detail in this kit is amazing.Drool Drool Drool
Well done so far.Cool
#165 Posted : 01 September 2020 12:50:39
Thanks Derek.
I certainly will not be putting all the body panels on when I display this one.BigGrin
#166 Posted : 01 September 2020 18:53:07
Okay, so I see the reference pictures of the real thing, so where’s the model. Laugh
Just stunning work, the level of detail you’ve created is breathtaking. Love Love
#167 Posted : 01 September 2020 20:37:33
Just catching up with your build Malc - very impressive work, I must say! True engineering in miniature and beautifully put together by a master modeller.
Very well done! Cool Drool
Kev.
#168 Posted : 05 September 2020 19:09:14
Hi Malc,
Looking fabulous Drool
#169 Posted : 05 September 2020 20:47:21
Hi mark, thanks for following the build and your comments.BigGrin
#170 Posted : 05 September 2020 20:49:34
Kev.
Hi Kev, Thanks for your comments. These Multi-media models can be very frustrating but the end result is very satisfying.
#171 Posted : 05 September 2020 20:50:58
Garth wrote:
Hi Malc,
Hello Garth, Thanks for keeping an eye on the build. This one is a real challenge.
#172 Posted : 06 September 2020 15:05:05
Amazing work Malc Drool Drool Love Love
Regards PhilCool
#173 Posted : 03 October 2020 18:46:58
Regards PhilCool
Thanks Phil BigGrin
#174 Posted : 03 October 2020 18:48:18
Now for the next "project within a project" The wire wheels !!!BigGrin
Each wheel comprises a beautiful machined aluminium rim, a cast hub with dimples where you have to drill and 72 0.35mm wire spokes and 5mm fitting steel tubes
#175 Posted : 03 October 2020 18:54:08
If anyone can do this "You`re the Man"
Cool Cool Cool Cool Cool
#176 Posted : 03 October 2020 18:54:58
A cast jig is provided for concentricity and alignment of the spokes. The finished wheel slips into the pre-printed tyres.
#177 Posted : 03 October 2020 18:56:54
Thanks Derek... It's certainly a challenge..BigGrin
#178 Posted : 03 October 2020 19:00:39
The jig has to be drilled and tapped M1.4 in 4 places.
I tried to centralise the rim with 0.3mm drills but ended up using a vernier much like a 4 jaw chuck.
The hub was cleaned up and each of the 72 holes opened to 0.5mm. It then gets secured in the center of the jig.
#179 Posted : 03 October 2020 19:06:53
Now the fun starts. BigGrin there are six rows of 12 spokes that get built in sequence from the inside of the wheel. Each spoke has a tube fitted to replicate the spoke tensioner. I bonded a row at a time and let it cure properly before going onto the next row.
I taped the jig to a plastic lid so that it could be rotated more easily and could catch any dropped parts....BigGrin
#180 Posted : 03 October 2020 19:09:00
After three rows and ...complete !!
This page was generated in 0.428 seconds.
