Well done Tony, a richly deserved recognition for all your efforts..... Regards Alan
Well done Tony, thoroughly deserved. Great build diary and very informative. Mark Regards Markwarren (Mark) Admin
Well done Tony  Great build so far mate  well deserved Regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Congratulations on joining the ranks of the 'Build of the Month' award winners Tony, well deserved for producing such a well planned and informative build diary of such a cool model.
Well done that man, keep it up!
Kev.Per Ardua Ad Astra
Congrats Tony. Well deserved build of the month. Very informative and well set out. Great work. Chris 👍👏 On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Congratulations Tony! Well deserved! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
thanks to everyone for such kind and supporting comments - I feel very humbled. Tony Happy Modelling
HACHETTE SPITFIRE Mk 1A – MONDAY 14th SEPTEMBER 2020Issues 27, 28, 29 and 30 have arrived. Again, a big thank you for selecting my diary as the build of the Month feature, that is so much appreciated. This month’s issues see us putting together the landing gear. Some very small parts to work with but glancing through the build instructions it looks like the build sequence will be very quick this month. This month’s build has us working on the left and right landing gear sections. As issues 27 & 28 are a “mirror” of issues 29 and 30 I will cover these 2 later build sections under the first 2. ISSUE 27 – LEFT LANDING GEAR (ISSUE 29 follows the same build rules but for the Right-hand side) PARTS CHECKLIST – PICTURE 1
27-01 Left Tyre 27-02 Main strut for landing gear 27-03 Wheel Fixture 27-04 Landing Gear Attachment 27-05 Landing Gear Attachment 27-06 Landing Gear Shaft 27-07 Landing gear spring 27-08 Three 2 x 3mm PM screws (1 spare) PICTURES 2, 3, 4 & 5We start by fitting the landing gear spring (27-07) over the landing gear attachment (27-04) When looking at the spring and comparing it to the printed instructions (Pic 3) the spring appears to have one end wound differently to that shown in the picture. While this was an initial concern putting the parts together shows that the spring is correctly formed and it’s the instruction picture that is slightly at odds. The spring is quite fine so no rough handling required for fear of damaging it. You just need to be careful when looping it over the landing gear attachment (Pic 4). PICTURES 6, 7 & 8We then take the landing gear shaft (27-06) and 1 of the PM screws. We press the landing gear shaft into the attachment part ensuring that is fully inserted. The shaft is then secured into place using one of the PM screws. Its worth noting that the screw is slightly longer than the position it fits into so even when fully secured you will find it sits a little higher than might be expected. PICTURE 9We then take the previously assembled part along with the Main Strut (27-02). PICTURES 10, 11 & 12We pass the Landing Gear Shaft through the Main Gear strut. Over the free end of the strut (gold coloured end) we place the remaining Landing Gear Attachment part (27-05). We need to ensure this is fitted the correct way around with the screw hole facing as arrowed in Pic 11. Using another of the PM screws we secure this part in place. PICTURES 13, 14 & 15We then take the Tyre (27-01), the Wheel Fixture (27-03) plus the previously assembled part. The tyre is held in place between the Wheel Fixture and Main Leg by a friction fit of the round Peg on the Wheel Fixture and a hexagonal hole on the leg. On the left-hand landing gear this fit was perfect but for the right-hand section the Wheel Fixture to leg joint is very loose and keeps falling out. A spot of super glue on this section will be required to resolve that issue. PICTURE 16 & 45These 2 pictures show both the left and right wheels fully assembled. The colouring matches the half Black/Half Sky that the underside of this aircraft will have. birdaj2 attached the following image(s): Happy Modelling
ISSUE 28 – FITTING THE LEFT LANDING GEAR (ISSUE 30 follows the same build rules but for the Right-hand side) PARTS CHECKLIST – PICTURE 1728-01 WHEEL GUARD 28-02 LANDING GEAR FIXTURE 28-03 LANDING GEAR INDICATOR 28-04 LANDING GEAR FIXTURE 28-05 LANDING GEAR FIXTURE 28-06 LANDING GEAR SPRING 28-07 LANDING GEAR INDICATOR PIN 28-08 FIVE 2 x 4mm PB screws (1 spare) PICTURES 18, 19 & 20We take the Landing Gear Fixture (28-05) and line up the hole on this part with the hole in the Landing Gear Bracket (28-04) Another interesting observation here is (pic 19 and 20) is what looks like a potential issue. The shaft length between the upward pointing peg and its securing hole looks longer than the part does in the build instruction. Again, no issues and its just the build picture that is slightly at odds. PICTURES 21 & 22We then take the Landing Gear Indicator Pin (28-07) and press fit this into place in order to secure the pivot arm in place. You will not press this in place with your fingers as it’s a very tight fit. The instructions call for a pair of pliers but I found the easiest way was to press down on a hard surface to get the pin in place. PICTURES 23 & 24Next, we take the Landing Gear Fixture (28-02) and the spring (28-06). The spring is placed into the spring holder. Care needed as this part is really small and if you drop this one on the floor chances are you will struggle to find it. PICTURES 25 & 26The Red Landing Gear Indicator (28-03) is next added to its slot in the landing gear fixture (28-02). PICTURES 27, 28 & 29This next stage needs some care as you need to insert the fork end of the pivot arm into the slot ensuring that the other end of the pivot arm sits on and does not foul the spring. The bracket is secured into place with one of the supplied PB screws. We then need to test that the indicator works without snagging. Pressing down on the pivot arm (as would be the case with wheels retracted) and the red indicator lowers. Releasing the pivot arm (as would be the case with wheels down) and the Red indicator plate rises. PICTURE 30Next, we take the wing section that we assembled last month. We will be working on the area that you can see circled in this picture. PICTURES 31 & 32What we then do is put the landing gear through the hole in the wing section ensuring the Next, 2 pivot arms on the landing gear sit in the matching slots in the wing section. Holding the wheel leg carefully in position we move it to the retracted state and check (PIC 32) the Next, end of the spring sits as shown in this picture. We then secure the Landing Gear Fixture (28-02) into place using 3 of the PB screws. PICTURES 33, 34 & 35With the wheel strut help in place we can test the indicator works. Wheels down (pic 34) and the red indicator rises. Wheels up (pic 35) and the indicator retracts. On the final model the raising and lowering of the wheels will be part of the working functions and it seems the attachment point for any servo will be as indicated in Pic 35. PICTURES 36, 37 & 38Last up is the Wheel Guard (28-01). This has 2 holes which fit onto the 2 pegs on the leg. The instructions call for this to be super-glued into position. In Picture 38 we can see the part in place from a side view. It looks as if its standing proud but we need to remember there is still an outer wing covering that will be added at a later stage which (hopefully) will ensure this part then sits flush with the lower wing section. PICTURE 39With both land gear assemblies in place this is how things are looking so far. With the springs behind the undercarriage legs they want to stay in this down position so for storage I will put them in the closed position and hold them down with a length of Tamiya Masking tape (as that is not likely to cause any issues). PICTURE 40And just to give an idea of what we can expect next time it appears Issue 31 will give us the lower left-hand wing skin. Interesting to see the roundel already in place so hoping that this is in place as well as the other markings have been so far. So, until the next time Stay Safe and Happy Modelling. birdaj2 attached the following image(s): Happy Modelling
Another fine update Tony. Keep it coming. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Nice work Tony, all coming together very nicely and it looks like it'll be a cool model when finished with some nice working features. I was considering resuming work on my Tamiya 1:32 Spitfire Mk.IXc after I've finished my current build (Voyager Space Probe) and seeing this build inspires me even more to get on with it!
Well done.
Kev,Per Ardua Ad Astra
Joined: 29/03/2011 Posts: 1,053 Points: 3,165 Location: Glenvista JHB
Hi Tony, Great update. This looks like a well made kit. Your step-by-step instructions are fantastic Looking forward to your next update. Kind regards, Garth "Measure twice, cut once!!!" Finished!!! HMS Victory, Current build: Black Pearl. On hold: Bismarck, Golden Hind, Flying Scotsman, Victory Cross Section, SOTS, Tiger 1. Wish list: USS Constitution.
(Edited out my earlier post as its not with the keeping of the forum) There will be a further update shortly as i received the next 4 issues (31 to 34) on friday. Interesting areas to highlight in this still to be done update as some fit issues have started to show up. The last few weeks have been so stressful so i just have to write up my next build instalment as the assembly and pictures are done. So please bear with me as i will be updating again soon. Kind regards Tony Happy Modelling
I don't know what to say my friend but I am thinking of you and I hope your mum soon gets better. All the best to you Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Martyn Ingram wrote:I don't know what to say my friend but I am thinking of you and I hope your mum soon gets better. All the best to you Martyn Martyn Thanks. I am hoping and praying for that. Tony Happy Modelling
HACHETTE SPITFIRE Mk 1A – SUNDAY 29th NOVEMBER 2020Well its an apology to start with for the delay in keeping this diary updated. Since my Mum passed away, a month ago now, I just cannot seem to get myself back to any sort of normality. Packs 31-34 were built some weeks ago but I never got around to writing this up until now. And in the mean-time Packs 35-38 have arrived and been built so I thought it about time I tried to show what has been happening so far. ISSUE 31 – FITTING THE UNDERSIDE OF THE LEFT WINGPICTURES 1 & 2Its worth a call out here to highlight just how well the parts are packed in this issue. The wing half is in its own card box and is protected inside with a bubble wrap bag. PARTS CHECKLIST – PICTURE 331-01 Underside of the Left Wing 31-02 Six 2 x 3mm PB screws (1 spare) PICTURES 4 & 5Interestingly this wing half has both a lift out panel as well as a hinged panel. No idea at this stage what the purpose of these are but I am sure all will be explained in future issues. Its also interesting to not that the same functioning panels do not appear on the right-hand wing half. PICTURES 6 & 7We test fit the lower wing half onto the previously assembled wing assembly. Everything lines up really well PICTURE 8We will use 5 x 2x3mm PB screws to secure the lower wing half in place. PICTURES 9, 10, 11 & 12Its again worth noting here that there is very little of the screw length left where it passes through the mounting holes to actually secure the lower wing in place. As the screw is going into plastic its really, really important not to overtighten as the lower wing fixing point will be stripped out and that is then going to take some serious re-work to put right. I think they could have used a 4mm screw for this fixing but we have to use what we get. And in terms of this stage that is all that is required to complete this part. birdaj2 attached the following image(s): Happy Modelling
HACHETTE SPITFIRE Mk 1A – SUNDAY 29th NOVEMBER 2020While not evident when assembling this stage, the completed part is a very poor fit when it comes to installing it on the lower wing. If there was some consolation it’s the fact that several online builders have also had similar issues. Therefore, as we press on, I will detail my “Correction” update that shows how I have tried to get a better fit on this particular part. ISSUE 32 – FITTING THE RADIATORS IN THE HOUSINGPARTS CHECKLIST – PICTURE 132-01 Angled Pipe 32-02 Radiator Housing 32-03 Radiator Housing Flap 32-04 Radiator Housing 32-05 Radiator Housing 32-06 Radiator Panels (1 to 4) PICTURES 2, 3 & 4On the metal etch fret we get 4 grill sections. Two of the pieces have vertical bars and two have horizontal bars. When joined together you get the grid pattern effect. Its worth noting that 2 of the parts are slightly smaller than the other 2 so just watch those instructions and use the correct parts. PICTURE 5The radiator grids are fitted to the radiator housing ensuring the grills are located behind the tabs as arrowed in this picture. PICTURE 6And this is how it looks with the first set of grills in place. PICTURES 7 & 8We then put the second grill section together and press fit that into place. PICTURES 9 & 10There are 2 side rails that we fix in place. These have tiny pegs that hold the grill sections down into their slots. PICTURES 11 & 12The last part installed is the radiator flap. This is just a press fit using the 2 holes on the radiator housing and the 2 pins moulded into the flap. We end up with the completed radiator housing along with a small pipe that will be fitted at a later stage. birdaj2 attached the following image(s): Happy Modelling
HACHETTE SPITFIRE Mk 1A – SUNDAY 29th NOVEMBER 2020ISSUE 33 – FITTING THE UNDERSIDE OF THE RIGHT WINGPARTS CHECKLIST – PICTURE 133-01 Underside of the Right Wing 33-02 Six 2 x 3mm PB Screws (1 spare) The arrows indicate the location for the troublesome Radiator which will be discussed in more detail later. PICTURE 2Not a great deal to update here as this is a direct copy in terms of the assembly as we did with the left-wing half in Part 31. PICTURE 3Of note however is this colour mismatch we see here between the sky colour on the metal centre section and the sky colour on the plastic right wing half. Not a great deal we can do about this as any thoughts of re-spraying would be hampered by the fact the markings are already in place. PICTURE 4The small pipe left over from the previous section is super glued into place on the lower wing section. PICTURE 5And we end up this section by press fitting the radiator assembly in place. Its at this point we can see the radiator des not sit fully down on the wing section and we are left with large gaps (arrowed) either side. If this was a run of the mill plastic kit, we would just fill this section and make good before painting, but as mentioned with the markings already in place, a re-paint is not really an easy solution. birdaj2 attached the following image(s): Happy Modelling
HACHETTE SPITFIRE Mk 1A – SUNDAY 29th NOVEMBER 2020RADIATOR FIT CORRECTIONI mentioned earlier that the press fit of the radiator onto the lower wing leads to large gaps either side of the piece. Looking at it I think one of the issues is the fact the lower wing section is quite “flexible” so when you are trying to press fit the radiator into place the wing flexes slightly preventing the radiator from seating properly/ I decided to look at the part and make the following corrections. Started by removing the lower wing section to make it easier to work on. PICTURES 1 & 2One of the first things to notice is that the backing of the radiator grills shows up as white/sky. My thoughts are that if looking into this section it would be quite dark so on that basis a slip of black paper was inserted behind the grill (Picture 2) to see what it looked like. I was quite happy with the dark background so replaced the paper test piece and painted the grill support area Black. PICTURE 3Another slight issue I noticed is that the 2 grill sections had a tendency to move thereby losing the squared grill look. Simply remedy for this was to just add a dab of superglue along the top section (arrowed) of the grill parts. PICTURE 4The grill sections are then put back into place. Here you can also see the 2 pegs that hold the radiator in place. Because there is not tight fit to this, I decided that reducing the height of these 2 pegs so that they sit slightly shallow when press fitted into the lower wing would then allow me to put in a couple of washered screws in the hope that it would pull the radiator tighter into the wing section. PICTURE 5Here you can see the result of reducing the peg height. The surfaces now sit slightly lower in the location holes in the wing section. PICTURE 6I then used 2 washer headed screws (pays to keep spares from other builds) and putting these in place allowed the radiator to be glued up and pulled tighter into place on the lower wing. When the glue was dry these 2 screws were then removed. Net result is that the radiator fit is better (still not perfect) than it was before. birdaj2 attached the following image(s): Happy Modelling
